Meteorology - Rainfall measurement
The discussion revolves around the measurement of rainfall in meteorology, specifically what it means when meteorologists predict a certain amount of rain, such as 5mm or 10mm, for a region. Participants explore the implications of these measurements, their reliability, and the mechanics of rainfall collection.
  • One participant seeks clarification on the meaning of rainfall measurements, questioning if there is a straightforward relationship between the mm value and the volume of water over a given area.
  • Another participant suggests that the forecasted rainfall amounts (5mm to 10mm) indicate that most locations will receive varying amounts of precipitation, with some receiving more and others none at all, emphasizing the generality of such forecasts.
  • A participant describes the mechanics of rainfall collection, noting that the funnel used in rain gauges amplifies the height of collected rain, which is measured in a tube.
  • One participant explains that 1mm of rain corresponds to 1 liter of water per square meter, providing a mathematical breakdown of the volume associated with rainfall measurements.
Participants express varying levels of understanding and interpretation of rainfall measurements, with no consensus reached on the reliability of forecasts or the implications of the mm values provided.
Participants highlight the generality of rainfall forecasts and the potential variability in actual precipitation amounts across different locations, indicating that assumptions about uniformity may not hold true.
Routaran
Hello, I wasn't sure exactly where to put this thread. Figured this was the most relevant section.
Anyway, I wanted to know what exactly do meteorologists mean when they say that a region will receive 5mm or 10mm of rain during the evening.
I read this wiki page
http://en.wikipedia.org/wiki/Precipitation_(meteorology)#Measurement
but it is all still clear as mud. I thought there was a relationship between the mm value given and the volume of water that would land over a given area but i am not sure.
Can someone please clarify? Is there anything straightforward like every square meter will get half a liter of water over 5 hours? or something to that effect?
Thanks.
They certainly mean anything precise by it because their own information is quite general. All this means is that most of the locations in the region will get somewhere between 5mm and 10mm of precipitation during the evening. Some will get more than that, and some will get nothing at all.
As a general rule of thumb, you should know that the lower the total (and 5 to 10mm is quite low) the lower the reliability of the forecast. A forecast of 10cm would give you a far likelier chance of getting at least something.
When rainfall is collected, it goes through a funnel into a tube. The funnel mouth is about 10x wider than the tube(I think), so the actual height of the collected rain is larger than what you would see in a box or whatever. The height on the tube is what is measured, though. The tube is shrunken to amplify differences in height, making it more accurate.
Thanks.
1mm rain means that every square meter covered with water with the height of 1mm. One meter is 1000mm, so the total volume is 1000 x 1000 x 1 = 10^6 cubic mm or 10^3 cubic cm or 1 cubic dm, which is one liter. So for every mm of rain you get one liter per square meter.
  • · Replies 53 ·
14K
  • · Replies 23 ·
  • · Replies 146 ·
11K
