How to increase the temperature of the ball mill in the lab?
To increase the temperature of a ball mill in a laboratory setting from 38 degrees Celsius to 60 degrees Celsius, the installation of a thermostat-controlled heater is recommended. Additionally, attaching heating plates to the ends of the ball mill can effectively raise the temperature using a simple power supply. These methods will enable the effective study of grinding aids such as CBA and HEA2, which require a minimum temperature of 60 degrees Celsius to function optimally.
  • Understanding of ball mill operation and temperature control
  • Familiarity with grinding aids like CBA and HEA2
  • Basic electrical knowledge for power supply connections
  • Experience with laboratory equipment setup
  • Research the specifications and installation process for thermostat-controlled heaters
  • Investigate different types of heating plates suitable for laboratory ball mills
  • Learn about the effects of temperature on the performance of grinding aids
  • Explore safety protocols for electrical modifications in laboratory equipment
Laboratory technicians, materials scientists, and researchers studying cement grinding processes who require precise temperature control in ball mills.
tuyetanh
I want to grind the clinker with grinding aids such as CBA, HEA2. However, these grinding aids act only with clinker above 60 celsius degree. The temperature of the ball mill in our lab is 38 celsius degree. Please tell me how to increase the temperature of our mill in the lab up to 60 celsius degree so that I can study the effect of these grinding aids. Thanks a lot.
Could you not install a thermostat controlled heater in your ball mill ?
Attach heating plates to the ends of the ball mill, then you can use a imple power supply.
10K
  • · Replies 42 ·
9K
