Check My Physics Work: Visual Aid Provided
The discussion revolves around a physics problem involving differential equations related to motion under the influence of gravity and drag forces. The original poster seeks verification of their work on transitioning between two equations related to velocity and acceleration.
  • Participants discuss the transition between a differential equation and its solution, with some questioning the correctness of the equations presented. Others explore the implications of changing the drag force and how it affects the differential equation.
The discussion is ongoing, with participants offering guidance on how to verify the solution through differentiation. There is a lack of consensus on the correctness of the equations, and multiple interpretations of the problem are being explored.
The original poster mentions that their homework does not require them to solve the differential equation but rather to understand the transition between the equations provided. There is also a mention of a specific case where the drag force is altered, prompting further questions about the resulting differential equation.
UrbanXrisis
Could someone please check my work http://home.earthlink.net/~urban-xrisis/phy002.gif ?
Urban, what was the problem with the solution in the other thread?
I couldn't really follow what was going on. I didn't know there was a solution. In physics, I was given 2 formulas:
dv/dt=-g+bv/m <- this being the differentiable equatioin
and also:
v=mg/b(1-e(-bt/m)) <- which showed the velocity at any time
My homework asks to "solve" for the equations but I'm in high school so it only expects me to jump from
dv/dt=-g+bv/m
to
v=mg/b(1-e(-bt/m))
without actaully solving it
From that, they ask questions like...what if the drag force = -bv^2 and they change it. Then they tell me to find the differential equation for the object's motion. I THINK that all I have to do is sub in the numbers but I'm not quite sure. Cyclovenom, you did a great job but I'm only on the basics :rolleyes:
Urban if you want to check your solution then derivate it with respect to time, and it should give the right side of the equation.
what does that mean? "give the right side of the equation"? Do I have the wrong equations?
For example:
For this differential equation
[tex]\frac{dy}{dt} = ay - b[/tex]
its solution is: [itex](y_{o} = 0)[/itex]
[tex]y = \frac{b}{a} - \frac{b}{a}e^{at}[/tex]
so if we substitute in the differential equation we should get both sides the same.
[tex]\frac{d(\frac{b}{a} - \frac{b}{a}e^{at})}{dt} = a(\frac{b}{a} - \frac{b}{a}e^{at}) - b[/tex]
we get:
[tex]be^{at} = be^{at}[/tex]
so that's the solution for our differential equation.
  • · Replies 34 ·
