| New Reply |
empty spaces and virtual particles in atom |
Share Thread | Thread Tools |
| Jul26-11, 05:59 AM | #1 |
as i know,bohr's discovery reveals that atom consist of central nucleus and electron orbit around them in empty spaces
my question is-why aren't virtual particles being produced in those empty spaces? |
| Jul26-11, 07:29 AM | #2 |
Recognitions:
1) That was Rutherford's discovery, not Bohr's.
2) The Bohr model (i.e. electrons traveling in discrete orbits around the atom) was disproven long ago. Electrons in atoms are described probabilistically, not as discrete particles traveling in planetary orbits, which would violate the Heisenberg Uncertainty principle. 3) Virtual particles are only a manifestation of a particular kind of mathematical treatment (i.e. perturbation theory). It is not clear that they have any independent "reality" .. many people would claim that they do not. However, virtual particles can be a useful mnemonic for qualitative rationalization of how the "communication" between the electron and nucleus obeys relativity. Namely, the electromagnetic force between electron and nucleus can be mathematically construed as an exchange of virtual photons which carry the momentum between the real particles. Thus if the nucleus suddenly disappeared instantaneously, there would be a slight delay before the electron was aware of it, because "virtual particles" emitted by the nucleus before it disappeared would still cause the electron to behave as if the nucleus were still there. Note that this is description is HIGHLY qualitative (verging on a pop-sci description). However, that is basically what the Feynman diagrams (which are a visual representation of the mathematical perturbation theory treatment) indicate happens. The reason this picture gained traction is because the QED description of the electron-nucleus interaction is very hard to solve exactly, and the perturbation theory approximation gave excellent agreement with experiment. In fact, QED successfully reproduced the relativistic shift of the H-atom energy levels called the "Lamb shift". This can be rationalized as follows: the virtual photons carrying the EM force between the electron and nucleus have a very small probability of becoming a positron-electron pair. These two cases would have different energies, and the Lamb shift is the manifestation of that effect ... QED calculations of the Lamb shift give incredibly good agreement with experiment. So, are there virtual particles in the empty space between electron and nucleus? Well, it kind of depends on your point of view. Personally, I find the QED description in terms of Feynman diagrams quite useful for qualitatively describing what is going on. It is also clearly responsible for providing incredibly accurate calculations in some cases. However, I also think it is important to recognize that this is still just based on a mathematical description ... the physical reality could be quite different. However, that last comment can be applied to pretty much any phenomenon in quantum mechanics and atomic physics. |
| Jul26-11, 09:55 AM | #3 |
| Jul26-11, 04:15 PM | #4 |
| Jul27-11, 03:06 AM | #5 |
| Jul27-11, 10:31 AM | #6 |
The atom works by having an electron's wavefunction smeared through-out the volume of the atom. We can't shrink atoms by simply moving the electrons in closer because the ground state electron wavefunction around an atom is already the most compact arrangement possible. While we cannot shrink an atom, we may be able to shrink an object by making the atomic wavefunctions overlap, such as in a Bose-Einstein condensate.
| Jul27-11, 10:35 AM | #7 |
This is one of the reasons that physics is not scale invariant (i.e. you can't build a functioning grandfather clock on an arbitrarily small scale): atoms are the building blocks of all matter and atoms have a definite size that can't be changed much.
| Jul27-11, 10:36 AM | #8 |
| Jul27-11, 11:11 AM | #9 |
Recognitions:
| Jul27-11, 11:19 AM | #10 |
The mass density of an atom is very high at its nucleus, therefore an alpha particle that is fired very close to the nucleus will experience the most deflection. But just because the density is high in the center does not mean that it is zero everywhere else. Think of the atom as a bowling ball surrounded by several meters of tissue paper (this analogy has severe limitations, I know). If you fire hundreds of bullets at it, most will go right through the tissue paper, miss the hard bowling ball at the core, and come out the other side with little deflection. But a few bullets will hit the ball and experience a large deflection. The Rutherford experiment did not say much about the low-density electron cloud surrounding the nucleus, but it did say something about the nucleus (its density, effective size, etc.). See here for more.
| Jul29-11, 07:56 AM | #11 |
| Jul29-11, 09:10 AM | #12 |
In everyday atoms "empty space" is not such a bad description. But the wave description is a much more accurate way to think about atoms...quantum theory just gives better insights than classical at atomic and sub atomic levels. Yet Sirius B, the white dwarf star, has a density of about 60 tons per cc, due to electron degeneracy...far above anything on earth. That's where electrons are smooshed together by gravity, forced in toward the nucleus...electron clouds get smaller. And if a star is massive enough, that contraction results in an even denser neutron star where electrons are forced into the nucleus by gravity....they combine with protons to produce neutrons.....which may be followed by the creation of a black hole which further compresses particles and "space" where even matter and time is compressed beyond our theoretical ability to understand. |
| Jul29-11, 09:19 AM | #13 |
Why aren't they produced everywhere? It's not like any particle, say a neutron, is sitting there solid, immoble, preventing it...all particles have are bouncing around due to quantum jitters and have wave characteristics. Is there anywhere quantum jitters don't exist: it's present in even quantum ground state and even degenerate conditions. |
| Jul29-11, 10:12 AM | #14 |
| New Reply |
| Thread Tools | |
Similar Threads for: empty spaces and virtual particles in atom
| What % of an atom is empty? | Atomic, Solid State, Comp. Physics | 12 | ||
| If virtual particles can appear, can real particles disappear? | Quantum Physics | 3 | ||
| There is no such thing as empty space in an atom. True? | Cosmology | 4 | ||
| Virtual colors for atom representation? | Chemistry | 8 | ||
| Hawking Radiation – Empty space virtual antiparticle-particle pairs | Astrophysics | 1 | ||
