Derivation of the differential cross section
The discussion centers around the derivation of the differential cross section in the context of particle scattering. Participants express a desire for a derivation that avoids the use of differentials and infinitesimal concepts, which some find vague or unsatisfactory.
  • Gavroy seeks a derivation of the differential cross section that does not rely on differentials or infinitesimal variables, expressing concern over the mathematical rigor of existing derivations.
  • Some participants provide intuitive examples of the differential cross section, such as scattering particles at specific angles, but these examples still involve differential concepts.
  • One participant argues that the differential cross section is defined based on its utility in describing scattering into infinitesimal solid angles, suggesting that a derivation without differentials may not be feasible.
  • Another participant challenges Gavroy's request by comparing it to describing the sun without using the term "sun," indicating that differentials are fundamental to the concept.
  • Gavroy clarifies that while they understand the derivative concept, they question the meaning of "infinitesimal" numbers in the context of the discussion.
  • A later reply invites Gavroy to define the derivative operator without referencing infinitesimals, suggesting that this might clarify the concept for them.
Participants generally disagree on the feasibility of deriving the differential cross section without using differentials or infinitesimal concepts. The discussion remains unresolved regarding the possibility of such a derivation.
Some participants express frustration with the reliance on calculus and infinitesimal concepts, indicating a potential limitation in their understanding or acceptance of these mathematical foundations.
Gavroy
hi
i am currently looking for a derivation of the differential cross section, that is not an abuse of mathematics, cause all derivation i found use differentials that are treated like fractions and so on?
greetings
Gavroy
I can't really get what's your problem...
If you need an intuitive example of differential cross section, try the one for scattering particles at a given angle. Differential cross section [itex]d\sigma[/itex] is an area on which you have to aim incoming particle to get it scattered at the angle between [itex]\theta[/itex] and [itex]\theta+d\theta[/itex]
When you say "differential cross section", are you talking about the particle physics concept?
Do you want a derivation of the differential cross section variable itself? If so, there isn't really a derivation, per se. The differential cross section is just defined to mean something useful: the amount of scattering into a infinitesimal solid angle (in units of an effective cross-sectional scattering area). If you mean a derivation of how the differential cross section depends on the system variables, that will depend on the specifics of the system. Here is an example from http://faculty.uml.edu/cbaird/95.658%282011%29/Lecture8.pdf" .
this is exactly what i found in many physics books, but i am looking for a derivation that does not use differentials and infinitesimal small variables. i am looking for a derivation, that does not use as I would call them "vague mathematical concepts".
and to clearify what i want to get:
[itex]\frac{d \sigma}{d \Omega}= \frac{b}{sin (\theta)} \frac{db}{d\theta}[/itex]
I am afraid you are looking for impossible, as those infinitesimal small steps are a very foundation of calculus...
Like looking for algebra without vague concept of multiplication.
You want a derivation of the differential cross section that does not use differentials? That's like asking for a description of the sun that never uses the word "sun". If you don't trust differentials, than treat everything as macroscopic angles and do the derivation, then at the end take the limit of infinitesimal segments to recover calculus.
it is not that i do not trust calculus
for example the derivative in the equation is well-defined
[itex]\frac{d}{d \Omega} : C^1 (\mathbb{R}) \rightarrow C(\mathbb{R})[/itex]
cause everybody here knows what a derivative is
but what do you mean, when you are referring to an infinitesimal small number?
Try to explain how do you define the operator:
Gavroy said:
[itex]\frac{d}{d \Omega}[/itex]
without using the term of "infinitesimal" changes. I believe you are able to provide mathematically correct definition. Then take the phrases you used in your explanation and you will have the definition of 'infinitesimality' fitting to your taste.
