Mech energy and perplexing waterslide
  • Thread starter Thread starter sanstereo
    Energy
The discussion revolves around mechanical energy concepts, specifically work, power, and kinetic and potential energy, as applied to two test problems involving a runner and a child on a waterslide.
  • Participants explore the energy dissipation of a runner and its relation to power output, questioning how to calculate total energy dissipated per step and per meter. They also discuss the implications of the given power in relation to running speed. In the second problem, questions arise regarding the configuration of the waterslide and how it affects the child's landing.
The discussion is active, with participants clarifying details of the problems and exploring calculations related to energy dissipation and speed. Some guidance has been offered regarding the relationship between energy dissipation and running speed, but no consensus has been reached on the specifics of the waterslide problem.
Participants are working under the constraints of a test preparation context, and there is a need for clarity on the problem statements, particularly regarding the energy dissipation per step and the configuration of the waterslide.
sanstereo
hello, glad this site exisits.
i got a test coming up on work, power, k and p energy, so forth . . .
i got two test problems here that i can't figure out for the life of me.
a) While running a person dissapates .6 j of mechanical energy per kg of body mass. if a 60 kg runner dissapates a power of 70 W during a race, how fast is the person running? Assume a running step is 1.5 m long.
b) A child slides without friction from a height of h along a cuved waterslide. She is launched from a height of h/5 into the pool.
it looks as though the angle is 45 degrees in the slide and i need to find the distance or the x value when she lands in the pool.
if anyone can help me out here or if you need further info, drop a line. thanks a lot in advance . . .
peace . . .
Does a) say 'per kg of body mass per step', by any chance?
yeah, sorry. it does say that, so add that to the problem. heh.
So if a person dissipates 0.6 J per kg per step, how much total energy does a person weighing 60 kg dissipate per step? Then, how much total energy does the runner dissipate per meter? How does this compare to 70 W? 70 W means 70 J are being dissipated each second - so, if a person dissipated 140 J per meter, that would mean it took a person two seconds to run a meter. You can get the speed from this.
In part b) - does the slide level off at the botom or does it end at an angle?
9K
