Bilinear Forms associated With a Quadratic Form over Z/2
  • Context: Graduate
  • Thread starter Thread starter Bacle
    Form Forms Quadratic
The discussion revolves around the transformation of quadratic forms over the field Z/2 into their associated bilinear forms. Participants explore the theoretical background, specific conditions for existence, and classification of these forms, particularly in the context of symplectic bases and Arf invariants.
  • One participant notes the formula for finding the bilinear form associated with a quadratic form over fields of characteristic different from 2, and seeks a simpler method for Z/2.
  • Another participant mentions that a symmetric bilinear form satisfying the condition Q(x) = B(x,x) only exists for special quadratic forms.
  • A request is made for clarification on the conditions under which the associated bilinear form B(x,y) exists.
  • Discussion includes the specific case of the bilinear form (x,y)_2 related to the intersection form in H_1(Sg,Z/2) and the classification of quadratic forms by their Arf invariant.
  • It is noted that there are 8 forms with Arf invariant 1 and 8 with Arf invariant 0, and that the Arf invariant classifies quadratic forms mod 2.
  • Participants discuss the equivalence of forms defined over F_2 based on their Arf invariant, contrasting this with classification over fields of characteristic different from 2 based on resolvents.
Participants express differing views on the existence of symmetric bilinear forms and the implications of the Arf invariant, indicating that multiple competing views remain unresolved.
The discussion highlights limitations regarding the specific conditions under which bilinear forms exist and the dependence on the definitions of quadratic forms and Arf invariants.
Bacle
Hi, All:
Given a quadratic form Q(x,y) over a field of characteristic different from 2, we can
find the bilinear form B(x,y) associated with Q by using the formula:
(0.5)[Q(x+y)-Q(x)-Q(y)]=B(x,y).
I know there is a whole theory about what happens when we work over fields of
characteristic 2, with the Arf -Invariant , Artin's and other's books on Geometric
Algebra and everything, which I am looking into.
Still, I wonder if someone knows the quick-and-dirty on how to transform an
actual, specific quadratic q form over Z/2 into its associated bilinear form.
Thanks.
The reason for all the theory is that there isn't a symmetric bilinear form satisfying Q(x) = B(x,x), except for special Q's. Observe that B(x,x) is a linear function of x...
Thanks, Hurkyl:
Would you give me some idea on the conditions under which the
associated B(x,y) exists?
I'm thinking specifically of the case in which the bilinear form is (x,y)_2 ; the intersection form in H_1(Sg,Z/2) ; all defined on a symplectic basis for Sg ---Sg is the orientable, genus -g surface, and a symplectic basis {x1,y1,x2,y2,...,x2g,y2g} for Sg is one in which (xi,yi)_2=1 and (xi,yj)=0 if i=/j .
We then say that q(x) is a quadratic form associated with the given bilinear form, if :
q(x+y)-q(x)-q(y)=(x,y)_2
And then we seem to classify these forms by their arf invariant; there seem to be 8 forms with Arf invariant 1 and 8 with Arf invariant 0 (the Arf invariant when working over Z/2 is an element of Z/2); given a choice of symplectic basis as above, the Arf invariant
is defined as : (q(x1)q(y1)+q(x2)q(y2) ).
Still, I don't know what the issue is with the forms with Arf invariant 1 . I know that the Arf invariant classifies the quadratic forms mod2, i.e., two forms defined over F_2 are equivalent iff they have the same Arf invariant ; just like we
classify quadratic forms over fields of characteristic different from 2 by their resolvent, i.e., all quadratic forms over fields of characteristic different from 2 can be diagonalized ( I think by symmetry) , and the sum of the square of their diagonals is an invariant , i.e., if forms Q,Q' are equivalent, then they will have the same resolvent.
  • · Replies 20 ·
20K
  • · Replies 0 ·
