New Reply
Best location for a light bulb filament using a concave mirror?
Share Thread Thread Tools
Jul26-11, 11:04 PM   #1
Where is the best location for a light bulb filament to be placed in a spotlight, when using a concave mirror?
It makes the most sense to put it at the focal point of the mirror if you want parallel light beams but are you supposed to have parallel light beams when you use a spotlight? Or do you want the beams to diverge slightly so the light covers a larger area? I also read that in some slide projectors, the light bulb is placed at the center of curvature.. is this the same thing as radius of curvature? Or are they meaning focal point? I'm just a little unclear..
Thank you in advance for your help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jul27-11, 09:10 PM   #2
See:
http://www.saskschools.ca/curr_conte..._app_lamps.htm
http://www.google.com/search?hl=en&q...og&sa=N&tab=wi
Some flashlights you can adjust the bulb for or aft of the focal point.
Jul27-11, 09:13 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by reganw View Post
Don't forget that no light bulb is an actual point source of light, so while some point on the filament may be exactly at the focus, the rest of is will be slightly off, giving a certain amount of spread.
Peter
Jul27-11, 11:13 PM   #4
Quote by PeterO View Post
Peter
Quote by Spinnor View Post
See:
Okay, that's great, thank you to the both of you! I can put together a sufficient answer with all of that info. Thanks again.
New Reply
Thread Tools
Similar Threads for: Best location for a light bulb filament using a concave mirror?
Thread Forum Replies
Temperature of Bulb Filament Introductory Physics Homework 5
light bulb filament Calculus & Beyond Homework 2
Finding the temperature of light bulb filament? General Physics 2
Light bulb filament question General Physics 1
Need help on this! Light bulb Filament Temperature with emissivity and δ given Introductory Physics Homework 1
