What is the critical value of the Immirzi parameter in loop quantum gravity?
  • Context: Graduate
  • Thread starter Thread starter marcus
    Parameter
The discussion centers on the critical value of the Immirzi parameter in loop quantum gravity (LQG) and its implications for black hole entropy. Participants explore theoretical frameworks, recent papers, and the relationship between the Immirzi parameter and black hole thermodynamics.
  • Some participants suggest that the Immirzi parameter has a critical value around 0.274, derived from number-theoretic considerations rather than being adjusted to fit the Bekenstein-Hawking entropy formula.
  • Others reference recent papers by Ghosh and Perez, and Mitra, which indicate that the Immirzi parameter does not enter multiplicatively in the leading term of black hole entropy, suggesting a shift in understanding.
  • A participant mentions that the Immirzi parameter's role in quantum corrections involves the number of spinnetwork links, which could introduce additional complexity to the black hole state.
  • Some contributions highlight the existence of competing views regarding the Immirzi parameter's values, with references to papers suggesting it could be greater than 1 or approach 0.
  • There is mention of a paper by Christian Corda that approaches black hole entropy from a different perspective but finds corroboration with loop quantum gravity results, indicating a broader discourse on the topic.
  • Participants express interest in the implications of various papers and the potential for different interpretations of the Immirzi parameter's significance in black hole physics.
Participants do not reach a consensus on the critical value of the Immirzi parameter or its implications for black hole entropy. Multiple competing views and interpretations remain present throughout the discussion.
Some discussions reference unresolved mathematical steps and differing interpretations of the Immirzi parameter's role in black hole thermodynamics, indicating a complex landscape of theories and models.
marcus
Dearly Missed
It now looks like the Immirzi parameter has a critical value which is determined numbertheoretically, not by the Bekenstein-Hawking S = A/4.
It used to be that with LQG the IP appeared multiplicatively in S = A/4 so that the value of the IP had to be ADJUSTED to get the S = A/4 equation right.
But this appears to be no longer the case. The B-H equation (S = A/4 + other terms ) has been derived in LQG without the Immirzi getting in multiplicatively in the leading term. So it is not forced or restricted.
Interestingly however it gets a critical value from other considerations which happens to be around 0.274. This comes out in two recent papers, by Ghosh Perez and by Mitra. I mentioned this in another thread:
marcus said:
From page 4 of Ghosh Perez:
Classically, the only natural value of the chemical potential is zero, which implies
1 = ∑(2j + 1) exp(−2πγ√[j(j + 1)]).​
(My comment: This is what determines γo the critical value of γ.)
Some background on the number 0.274 is here:
http://arxiv.org/abs/0906.4529
See equation (9) on page 4. A more precise value and its square root:
(0.274067...)1/2 = 0.5235...
The Immirzi comes into the picture when you add a purely quantum correction term involving an index of refinement N. N is the number of spinnetwork links that pass out thru the BH horizon. So if you REFINE the spinnetwork by adding nodes and links to it then intuitively you can be increasing N and adding a kind of quantum hair to the quantum BH state. The Immirzi determines the chemical potential the energy decrease associated with adding one more puncture. (Intuitively, dividing the area and curvature of the horizon up finer and finer.)
I will go get the links to the recent papers by Ghosh Perez and by Mitra.
http://arxiv.org/abs/1107.1320
Black hole entropy and isolated horizons thermodynamics
Amit Ghosh, Alejandro Perez
(Submitted on 7 Jul 2011)
We present a statistical mechanical calculation of the thermodynamical properties of (non rotating) isolated horizons. The introduction of Planck scale allows for the definition of an universal horizon temperature (independent of the mass of the black hole) and a well-defined notion of energy (as measured by suitable local observers) proportional to the horizon area in Planck units. The microcanonical and canonical ensembles associated with the system are introduced. Black hole entropy and other thermodynamical quantities can be consistently computed in both ensembles and results are in agreement with Hawking's semiclassical analysis for all values of the Immirzi parameter.
5 pages
http://arxiv.org/abs/1107.4605
Area law for black hole entropy in the SU(2) quantum geometry approach
P. Mitra
(Submitted on 22 Jul 2011)
SU(2) loop quantum gravity can be considered with the level k of the Chern-Simons theory held fixed. Then the black hole entropy is proportional to the area without any logarithmic correction. However, if k is made large, there is the -(3/2)log A correction.
5 pages
MTD2 spotted the paper by Parthasarathi Mitra and logged it onto our bibliography a couple of days ago. It seems like an important paper to me, in a similar spirit and of comparable importance to the one by Amit Ghosh and Alejandro Perez.
Note that "quantum geometry" as used in the the Mitra paper is just a synonym for Loop Quantum Gravity. It was Ashtekar's preferred name for the Loop approach. Also notice that Mitra's result is not the same. There is a tension. But they have an important similarity in that the Immirzi does not enter multiplicatively in the leading term and so does not need to be adjusted in order to make S = A/4. That is how I read it anyway. See what you think.
EDIT: brief mention of today's posting by Christian Corda at the Prato ITP
http://arxiv.org/pdf/1107.5334
Part of the re-understanding of BH entropy that is happening in various schools of thought not just Loop.
He comes at it from a different direction but happens to find Loop corroboration, citing Dreyer 2003 at the top of page 7 and Ghosh Mitra 2005 at the bottom of page 8 and also another LQG BH paper I didn't know of, his reference [19] J. Zhang 2008.
He has the entropy depend on an "overtone number" N, in subleading term. They also have a refinement number N that they let run to infinity, as he does, affecting the subleading terms: "quantum hair" as Alejandro Perez says. Not the same as Corda's N but curiously analogous.
atyy said:
Two other papers that mention values of the Immirzi parameter are
http://arxiv.org/abs/0909.0939 (abs(IP)>1)
http://arxiv.org/abs/0905.4082 (IP -> 0)
You mentioned Bianchi Perini Magliaro. I'll take a look. Could you tell me where they give a value of the IP? My eyes get tired scanning. And do they let the IP run from that critical value down to zero? Could be interesting. I vaguely remember reading that BPM paper but have forgotten detail.
As its reference [19], Corda's paper cites a 2008 one by Jingyi Zhang published in Physical Letters B. It was new to me so I post the abstract here for a closer look. I see it is another one where the author comes in from a different direction and happens to find a quantum correction to the entropy which agrees with what LQG found. Nice to get some confirmation from another approach:
http://arXiv.org/abs/0806.2441
Black hole quantum tunnelling and black hole entropy correction
Jingyi Zhang
(Submitted on 15 Jun 2008)
Parikh-Wilczek tunnelling framework, which treats Hawking radiation as a tunnelling process, is investigated again. As the first order correction, the log-corrected entropy-area relation naturally emerges in the tunnelling picture if we consider the emission of a spherical shell. The second order correction of the emission rate for the Schwarzschild black hole is calculated too. In this level, the result is still in agreement with the unitary theory, however, the entropy of the black hole will contain three parts: the usual Bekenstein-Hawking entropy, the logarithmic term and the inverse area term. In our results the coefficient of the logarithmic term is -1. Apart from a coefficient, our correction to the black hole entropy is consistent with that of loop quantum gravity.
9 pages; Physics Letters B Volume 668, Issue 5, 23 October 2008, Pages 353-356
It's easier to find it in the abstract of http://arxiv.org/abs/1105.0566, which builds on BPM.
There are very interesting comments on the meaning of this limit in the last two paragraphs of http://arxiv.org/abs/1105.0216.
18K
  • · Replies 94 ·
32K
9K
  • · Replies 102 ·
29K
  • · Replies 28 ·
