Help with some Resistance Questions
  • Thread starter Thread starter Hollysmoke
    Resistance
The discussion revolves around understanding resistance in electrical circuits, specifically focusing on calculations involving resistivity, wire dimensions, and ratios of resistance. The original poster presents multiple questions related to determining resistance values and comparing wire thicknesses.
  • The original poster attempts to apply the resistance formula and seeks guidance on how to find ratios and start solving specific questions related to resistivity and wire dimensions. Participants question the clarity of the problem and the parameters involved.
Some participants have provided insights into the resistance formula and parameters, while others express a need for clarification on specific values and concepts. There is a mix of understanding and confusion, with some participants sharing their thought processes and calculations.
The original poster mentions not looking for direct answers but rather guidance on how to approach the problems. There is a reference to a lab context, which may impose specific constraints or assumptions regarding the values used.
Hollysmoke
Okay we just start electricity in class and almost instantly we got a small lab. I did part of it, but I am having trouble with some of the questions and have no idea where to start from.
The first question is Determine the R value of a resistor that uses 4 m. of copper wire with a thickness of 1/3x the one used in the lab.
Now I have to find the ratio, but how? Also the resistor board used is 1 meter. I'm not sure, but would it be
R2= Resisitivity x 4 m. / Pie (4r)^2
R1= Resistivity x 1 meter / Pie r^2
How do I find the ratio?
2nd question was "Determine how much wider the diameter of the thick nichrome wire is in comparison to the thin nichrome wire".
How would I start such a question?
3rd question was "If the resistivity of nichrome is 100x10^-8 ohms/meter, determine the resistivity of copper"
How would I start to solve this question also?
Thanks (I'm not looking for an answer, Just how to start solving it)
How do you find the ratio? I'm sorry but I don't quite understand your problem. You seem to know all the parameters. What is the problem? If the thickness is an issue then the thickness refers to the diameter (twice the radius). And you have used
[tex]R = \rho\frac{L}{A}[/tex]
so where are you stuck?
Cheers
Vivek
Doesn't matter, I figured it out and I got it right ^^
ummm can u please temme how u did it?? haven't done electricity for a while now and can't seem to remember how to do it.. what is the value of RHO ( the P symbol ) in this case??
thanks
okay so we have the resistance of the copper from the lab, which we use
R1=P x L / A
Then we have the changes, which is 4x length and 1/3 the thickness. So, since we want the value of the resistor, we do:
R2=P x 4L / pie (1/3r^)2 <--- this is pie r^2 because the wire is circular
Since the resistance of the wire was 0.4 ohms (I'm doing this all off by memory BTW because I handed in my lab) then all we have to do is find the ratio. Since we have 1/3 in the brackets, we square to get 1/9, then the ratio is 4 / 1/9, which is 1/36. So 0.4 x 1/36 = 1.1 x 10^-2 ohms.
  • · Replies 21 ·
12K
  • · Replies 44 ·
