Help finding plans for a simple rankine cycle
This discussion focuses on building a simple closed-loop Rankine cycle for generating electricity, suitable for novices. Key components include a heat source, working fluid, turbine, and radiator. Participants emphasize the importance of understanding pressure dynamics and suggest alternative designs like velocity turbines for safety. Resources such as Wikipedia and specific turbine websites are recommended for further exploration.
  • Basic understanding of thermodynamics and thermal energy conversion
  • Familiarity with Rankine cycle principles
  • Knowledge of turbine types and their operational mechanics
  • Research skills to find materials and designs online
  • Research "DIY Rankine cycle projects" for practical guides and plans
  • Study "velocity turbine design" to explore safer alternatives
  • Learn about "material selection for high-temperature applications" to ensure safety
  • Examine "thermodynamic efficiency in closed-loop systems" for performance optimization
Novice engineers, hobbyists interested in renewable energy, and anyone looking to experiment with thermal energy conversion systems.
pagerussell
Hello,
I am a complete novice and would like to build a simple closed loop rankine cycle that generate electricy, even if it only enough to power a light bulb. I want to learn more about thermal energy conversion in a hands on way, but I am having trouble finding any simple, easy to follow instructions online detailing how to go about building something like this:
a heat source applied to a working fluid, which then boils to turn a small turbine before being routed to a radiator, where it gives off its heat. then compressed and sent back to the heat source.
Like I said, i am novice and would prefer not to catch a face full of hot steam, so I would love some detailed instructions.
Anyone have a link to a project they really liked? or a book? something, anything really.
Thanks
You probably won't be able to build a good one. Turbines tend to run on high pressure gradients, which in other recent thread; pressure, steam and someone not knowing what they are doing is a bad combination.You could however build something slightly different. Which is based on a velocity turbine. You heat the fluid to build pressue, then use a nozzle to convert the pressure to velocity.
see http://en.wikipedia.org/wiki/Turbine for different turbine types.
www.infinityturbine.com
www.redrok.com
There are many DIY non engineers making simple rankine cycles. You can build anything you put your mind to build. Just research what materials will work best for the intended heat and expected pressures. You have access to everything you need via google. Build your own turbine if you like. There are a lot of different designs and plans out there. No degree required I assure you.
