Is the speed of light constant
The discussion revolves around the constancy of the speed of light and the implications of time dilation and relativistic effects as described in hypothetical scenarios involving two observers, one stationary and one moving at a significant fraction of the speed of light. Participants explore the complexities of measuring light speed from different frames of reference and the challenges in conceptualizing these relativistic effects without relying heavily on mathematical formulations.
  • One participant presents a scenario where two observers measure the speed of light under different conditions of time dilation, questioning how both can measure the same speed of light despite differing time rates.
  • Another participant challenges the clarity of the original scenario, particularly regarding the concept of maintaining the same observational point while one observer is moving at high velocity.
  • A different participant offers an alternative scenario involving two observers and mirrors, illustrating how relativistic effects do not alter the measured speed of light for either observer despite their different states of motion.
  • Some participants emphasize the need to consider both time dilation and length contraction when discussing the Lorentz transformation and its implications for measuring light speed.
  • One participant expresses difficulty in understanding abstract concepts without concrete analogies, suggesting that hypothetical scenarios can complicate comprehension.
  • Another participant notes that analogies can be limiting and may hinder proper understanding of relativistic principles.
Participants express varying levels of confusion regarding the original scenario, with some agreeing that it lacks clarity. There is no consensus on the best way to conceptualize the effects of relativity, and multiple competing views on how to approach the problem remain evident throughout the discussion.
Participants highlight limitations in the original scenario, such as assumptions about simultaneity and the nature of measurements in different frames of reference. The discussion also reflects a dependence on hypothetical constructs that may not accurately represent physical realities.
This discussion may be of interest to individuals exploring concepts of relativity, time dilation, and the speed of light, particularly those seeking to understand these ideas through hypothetical scenarios and analogies.
John15
A hypothetical senario. As velocity increases time slows, time dilation.
2 observers 1 in normal Earth time 2nd traveling at velocity where time passes at 1/2 rate. Both observers maintain same relative observational point. For sake of scenario Light speed = 100 units per second.
Measured course of 200 units. Beam of light shone down course, both observers start timers at start and stop timers as light passes the 200 unit marker.
Observer 1s timer shows 2 seconds passed, observer 2 shows 1 second passed (1/2 normal time rate)
Speed of light is constant for all observers so how can observer 2 time light at twice normal rate? Where is the above scenario flawed?
Please remember this is a hypothetical scenario so how observer 2 maintains velocity is not important.
2 observers 1 in normal Earth time 2nd traveling at velocity where time passes at 1/2 rate. Both observers maintain same relative observational point...
I don't think your described scenario is clear. I especially wonder what is meant by the above. How do two observers "maintain the same relative observational point" when one of them is moving extremely fast relative to the other?
Another questionable part: "Measured course of 200 units."
Measured by whom? In what frame of reference?
I think that, somewhere in your formation of this problem, you may have made the error of considering one frame of reference as privileged.
I agree with zadignose, your scenario is a bit confusing. Hopefully I can offer a scenario that will clear it up;
Let's say that light travels at 200 units per second.
1000 units away from Alice is a mirror that is at rest relative to her (i.e. they are a constant distance away from each other). Alice shines a torch at the mirror, taking the speed of light and the distance in ten seconds Alice will detect the light from her torch. If Alice measures the distance between her and the mirror she can calculate the speed of light using distance/time.
In another scenario Bob is in a spaceship. At rest relative to him is a mirror 1000 units away. Bob shines a torch at the mirror and at the same time immediately accelerates up to 0.5c (lets say the acceleration time was instantaneous and ignore the impossibilities for a second). By the time the light has hit the mirror Bob is only 500 units away. Eventually Bob detects the light from his torch. The time between Bob turning on his torch and the time between him detecting the reflected light is 6.66 seconds. But this does not mean that Bob measures the speed of light to be faster because he was moving relative to the mirror, if Bob was to take his and the mirror's closing speed into account he would measure the speed of light as the same as Alice!
You are assuming that both observers can instantly know when the light passes the 200 unit maker but they cannot see that happening until the light reflects off the marker and comes back to them so that they can stop their timers.
So observer 1's timer will reach 4 seconds by the time the light travels to the marker an back to him, correct?
Now for observer 2, things are a little bit more complicated because we have to figure out where he will be when the light reflects off the marker and gets back to him and for that we will have to know how fast he is going. So why don't you figure that out instead of leaving all the work up to us. Then figure out where he will be when the reflected light reaches him.
After you do that, you will have a description of the scenario in terms of several events in the rest frame of observer 1. Then you can apply the Lorentz Transform to see what the coordinates of those same events are in the rest frame of observer 2 and you will see that he will also see that the speed of light is the same for him as it is for observer 1. Hint: in addition to time dilation there is also length contraction for observer 2.
The Lorentz transform involves more than just time dilation. You have forgotten to include length contraction and the relativity of simultaneity.
Thanks for the replies. To be honest I think in concepts so unless I can picture things in shall we say a real life situation then equations, like lorentz transformation, are difficult to understand unless they are explained and as I am on a teach yourself physics with no-one to help explain things it is not easy. For example why does moon orbit the earth. An answer of - the moons speed balances the gravitational force acting between them is fine I don't at this point need a lot of equations explaining exactly all the forces involved it just complicates things although I accept the maths is necessary at times.
Perhaps the scenario should have been a hypothetical racecourse 200 units round with hypothetical horses capable of light speed and both observers timing at the start/finnish line.
I tried this on another forum and got absolutly nowhere apart from no-one can observe light going faster than c which as an explanation is worse than useless. After thinking about it myself I came up with the answer that in order for light to remain constant for both observers then the relative distance must 1/2 to counteract the reduction in time, which I was told was rubbish. Looking at the above replies I suspect that I may not be to far out.
Would it be possible to explain relativity of simultaneity in understandable language so I can fit it into the picture, hopefully.
Distance and time dilation as you approach c obviously opens some interesting approaches to how the universe works.
The big problem is that hypothetical analogies with impossible objects can't help you up to a point but can also prevent you from getting a proper understanding. It's important to remember that analogies are simply that.
Do you know how to plot a straight line on a piece of graph paper given an equation of the form y=mx+b
I tried this on another forum and got absolutly nowhere apart from no-one can observe light going faster than c which as an explanation is worse than useless. After thinking about it myself I came up with the answer that in order for light to remain constant for both observers then the relative distance must 1/2 to counteract the reduction in time, which I was told was rubbish. Looking at the above replies I suspect that I may not be to far out..
Hi John, I'm with you mate!
I've only been learning this stuff for a short time, but decided to do it with as little math as possible for very similar reasons. I know to really understand it I'll have to learn the math at some point, but I have to be able to visualise it first as well I guess.
For me relativity of simultaneity is simply saying that if two events are separated by any distance, and as there is speed limit to how fast we can observe those events, then it makes sense that if I am nearer to one of them, I will see it before you and vise-versa.
So if I see two events happen simultaneously, and you are moving with respect to me, then you can't see those two events happen simultaneously.
So you would need to re-think your initial thought experiment, as both observers won't agree on when the light beam was at the start and finish points.
If you want some pictures to help you get going on what Special Relativity is all about, I made a series of animations to help someone else try to understand how the Michelson-Morley Experiment lead to SR. You can see them at post #78 and #79 on page 5 of this thread:
https://www.physicsforums.com/showthread.php?p=3046767#post3046767
Following on. Time effectively stops at c, if distance also shrinks to 0 then what are the implications, I understand that at c mass becomes infinite and needs an infinite amount of energy to push it but if distance reduces to 0 then it must be density that becomes infinite and energy is trying to push it into 0 space or effectively a singularity, which obviously cannot happen, if that makes any sense.
Understand about the differences in observation, obviously not what it was called.
It would not be the same observational point as one is moving. And either way, it is relative to the second observer that it is taking 1 second as he is already moving .5c
Quick question, following on.
Do length and time reduce to 0 at the speed of light (a singularity)?
If so is this related in any way to a black hole singularity.
Personally I don't see any way realistically for an infinite singularity to exist.
No matter how much you accelerate, you can never achieve the speed of light. As soon as you stop accelerating and make a measurement of the speed of light, you will get the same answer as you got before you started.
This has nothing to do with black holes.
You are right, in special relativity, you cannot reach the speed of light.
Read the FAQs for more information.
Light obviously reaches the speed of light. Question is then what happens to it at this speed that stops it going any faster?
It never goes any slower either. That is just its speed, it does not suddenly stop at c because it never goes at anything other than c.
I understand that that is just its speed and that its constant whatever the speed of its source but that does not explain why. Whereas if time = 0 at that speed then we would have a time barrier much the same as the sound barrier, you cannot go backwards in time, also if length = 0 then that would also help explain why mass cannot travel at c, hence why photons have no mass, mass must have a volume.
Another thought, if t = 0 at c then after the BB when all was energy traveling at c then inflation could have taken as long as it liked as time would only have come into existence with the formation of mass which travels at less than c.
Did you read any of the FAQs, especially this one?
https://www.physicsforums.com/showthread.php?t=511170
That FAQ points out that the idea of time and length for a photon has no meaning. It's not that they are zero, it's pointless to discuss the concept.
As I said in an earlier response, no matter how much you accelerate, when you stop and measure the speed of light, you get the same answer as before you started. That is the reason you can never reach the speed of light, not because something weird happens when you get there. You're always just as far away from going the speed of light as you were before you started. There is no barrier ahead that prevents you from achieving the speed of light.
I'm not sure what kind of a response to your question of why would satisfy you. Are you asking why we believe these things about light or are you asking why nature behaves this way?
Since the idea of "t = 0 at c" is a meaningless idea, then the "if" in your thought cannot lead to a meaningful conclusion after the "then" in your thought.
Why don't you focus your thoughts on trying to understand the Theory of Special Relativity which can be understood instead of on meaningless ideas? Until you do that, I doubt that you will be able to understand why we say that "t = 0 at c" is a meaningless idea and you'll be forever confused and wondering if scientists really know what they are talking about.
Have read the FAQ. To me it says that a photon moves at the speed of light because relativity says so and time and length cease to have any meaning. How can time and length cease to have any meaning to me that means the universe ceases to exist at c.
Relativity says that a photon would have to be moving at c in its own rest frame, as everything is relative I actually see no problem with this statement even though the FAQ says it does not make sense. From what I have read nothing can exceed c so if you are traveling at c then relatively speaking light would be traveling at 0 exactly the same way as if 2 cars are both traveling at 60mph in the same direction their relative speed is 0 and the relative distance traveled would also be 0 unless they are moving in different directions. The speed and distance traveled by the cars are obviously relative to all observers in all directions moving at any speed. At c we have a different situation as observers can only observe from the side or behind and at the same or lesser speed, so to all observers you can only appear to be standing still or moving away from, you cannot be observed by anything you are moving towards so to them you would cease to exist until you stopped in front of them, and you cannot observe anything you are moving away from so observation is limited. I assume this is where relative time and length come from.
While most people seem to accept the physical constants for what they are I cannot do so, to me there must be a reason why c is c , G is G an electron is the mass it is etc.
Other things like density going to infinity in a black hole do not make sense but seem to be accepted, nor does the BB singularity for that matter.
More meaningless thoughts and ideas. That's what happens when you refuse to believe the answers in the FAQs.
This forum is to help people learn and understand relativity. If you don't want do that, you should quit posting or you'll likely get yourself banned as you're violating the rules.
Hi John,
This video might help understand the reason.
It is in 3 parts and is about 30 mins in length.
http://www.youtube.com/watch?v=tnQnAaVGPK0&feature=related"
http://www.youtube.com/watch?v=04WMUMsAQvU&NR=1"
http://www.youtube.com/watch?v=RMelmxYZWp4&NR=1"
In classical mechanics the "why" is explained by Maxwell's equations, and in quantum mechanics the "why" is explained by the fact that photons are massless.
Really? You see no problem with the statement that 299792458=0
The statement 299792458=0 Speed of light (stable, no acceleration)
7500 = 0 Speed of the Earth (unknown acceleration )
I see no difference other than scale.
c is therefore a more stable reference frame than the Earth which we use.
You are missing the point. The speed of Earth may be 7500 in one frame and 0 in another frame. But it's never 7500 and 0 in the same frame.
(a) The definition of an object's rest frame requires the object to have speed 0.
(b) The definition of any inertial frame requires light to have a speed of 299792458 m/s.
Therefore if there were such a thing as an inertial rest frame for light, the speed of light in that frame would have to be simultaneously 0 and 299792458 m/s. This is nonsense and so such a frame cannot exist.
You are correct, the scale is unimportant. Both statements are false and can be scaled to the equivalent false statement 1=0.
You are incorrect if you believe that relativity asserts the second and you are doubly incorrect if you believe that can justify asserting the first. As DrGreg pointed out there is no frame where the speed of the Earth is v = 7500 = 0.
The Earth is moving through space at a minimum of 7500kps. There is nothing in the universe that I know of that has 0 velocity therefore nothing that can have a rest frame of 0. As I understand relativity it requires uniformly moving observers, c is the only thing I can think of that has guaranteed uniformity of motion. Light has a speed of 299792458 in our frame of reference, at c it would be 0 in that frame of reference.
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 34 ·
  • · Replies 26 ·
  • · Replies 22 ·
