Finding a start to simple preamp circuit (1 opamp)
  • Thread starter Thread starter ski
    Circuit Opamp
This discussion focuses on designing a simple preamp circuit using a single operational amplifier (opamp). Key configurations include the inverting amplifier and non-inverting amplifier, where the gain is controlled by feedback resistors. The user seeks guidance on calculating time constants and selecting component values (C, R1, R2, R3) for specific frequency responses (50 Hz to 2000 Hz). Resources such as electronics tutorials and application notes from opamp manufacturers are recommended for further learning.
  • Understanding of operational amplifier configurations (inverting and non-inverting)
  • Basic knowledge of feedback principles in electronic circuits
  • Familiarity with time constant calculations in RC circuits
  • Ability to interpret circuit diagrams and schematics
  • Research "inverting amplifier design using opamps" for practical examples
  • Study "non-inverting amplifier gain calculations" to understand resistor ratios
  • Explore "time constant equations in RC circuits" for frequency response analysis
  • Consult "opamp application notes" from manufacturers for detailed circuit designs
Electronics enthusiasts, hobbyists designing audio equipment, and students studying circuit design who seek to understand operational amplifier applications in preamplifier circuits.
ski
http://www.littleboyinc.com/uploader/uploads/opamp.JPG
I searched all over to get some notes on how to handle opamp circuits like this with feedback, but nothing on when there's no resistor in series with the input source. Can anyone help me out on where to find examples? This sort of thing isn't covered in my text, and I just need a push to find equations to use.
All right, here's what I've got:
Flo (low frequency of 50 Hz) = 1/(2pi*tau)
I repeated for Fhi (2000 Hz).
I solved for tau, which is some combination of C, R1, R2, and R3.
Now that I have two time constants, how do I determine what the combination of C and R's to solve for?
Thanks for the help so far, very much appreciated :)
There are a few ways you can approach designing a simple preamp circuit using just one opamp. One option is to use an inverting amplifier configuration, where the input signal is connected to the inverting input of the opamp and the output is fed back to the inverting input through a resistor. This resistor serves as the feedback element and can be adjusted to control the gain of the circuit.
Another option is to use a non-inverting amplifier configuration, where the input signal is connected to the non-inverting input of the opamp and the output is taken from the output of the opamp. In this case, the gain is determined by the ratio of the feedback resistor and the input resistor.
To find examples and equations for these types of circuits, you can refer to online resources such as electronics tutorials or application notes from opamp manufacturers. You can also try looking for circuit diagrams or schematics for similar preamp circuits that use a single opamp. These can serve as a starting point for your design and can be modified as needed.
Additionally, if your textbook does not cover this specific topic, you can try looking for other textbooks or reference books that focus on opamp circuits and their applications. These resources may provide more in-depth explanations and examples for designing preamp circuits using just one opamp.
Overall, the key is to experiment and try different configurations to see what works best for your specific application. Don't be afraid to ask for help or advice from other electronics enthusiasts or professionals, as they may have experience with similar circuits and can offer valuable insights. Good luck with your project!
  • · Replies 22 ·
