Salts and acids/ bases conceptual question
NH4NO3 is classified as a weakly acidic salt due to its composition of the conjugate base NH3 and the strong acid HNO3. The strong acid HNO3 contributes a very weak conjugate base, NO3-, which does not affect the pH of the solution. Conversely, NH3 is a moderately weak base, making its conjugate acid NH4+ a moderately strong acid that releases protons in solution. This results in a net acidic effect in the solution.
  • Understanding of acid-base theory, specifically the concepts of conjugate acids and bases.
  • Familiarity with the properties of strong acids, such as HNO3.
  • Knowledge of weak bases, particularly NH3 and its behavior in solution.
  • Basic grasp of pH and its measurement in aqueous solutions.
  • Study the properties and behavior of strong acids like HNO3 in aqueous solutions.
  • Explore the concept of conjugate acid-base pairs in detail.
  • Investigate the pH effects of various salts, focusing on weakly acidic and basic salts.
  • Learn about the role of ammonium ions (NH4+) in acid-base chemistry.
Chemistry students, educators, and professionals interested in acid-base chemistry and the behavior of salts in solution.
gkangelexa
My book says the following:
NH4NO3 is weakly acidic as a salt because it is composed of the conjugates of the base NH3 and the strong acid HNO3.
Why does that make it weakly acidic exactly??
Is it because the HNO3 is a strong acid, therefore it won't steal the protons that are released from the NH4 in solution?
Chemistry news on Phys.org
You pretty much got it.
Nitric acid HNO3 is a strong acid, so it's conjugate base, NO3- is a very weak base. It will not affect the pH of the solution.
Ammonia NH3, on the other hand, is a moderately weak base, so it's conjugate acid NH4+ is a moderately strong acid. It will release protons in solution.
So, as you say, the NH4+ releases protons, the NO3- does not pick up protons, so the net effect is an acidic solution.
