Frame Dragging & Black Holes: CTC Possibility?
  • Context: Graduate
  • Thread starter Thread starter Imax
    Frame Frame dragging
The discussion centers around the possibility of closed timelike curves (CTCs) being induced by frame dragging around black holes, particularly in the context of different metrics such as Kerr and Kerr-Newman. Participants explore theoretical implications, observable characteristics, and the conditions under which CTCs might exist.
  • Some participants propose that CTCs are predicted to exist within the ring singularity of the Kerr metric and just outside the ring singularity of the Kerr-Newman metric.
  • Others argue that frame dragging cannot induce CTCs outside the event horizon of a black hole, as it would require a black hole to rotate so fast that the horizon is eliminated.
  • A participant speculates about the observable characteristics of a CTC outside the event horizon, suggesting that causality would be lost within a CTC.
  • There is a discussion about the relevance of CTCs within spacetime and whether they are necessarily a negative aspect of theoretical models.
  • One participant questions whether CTCs are generally hidden behind horizons in metrics associated with frame dragging, raising concerns about the assumptions made in constructing physically meaningful manifolds.
  • Another participant suggests that properties like time orientability and global hyperbolicity may imply that CTCs are necessarily hidden behind horizons.
Participants express disagreement regarding the existence of CTCs outside the event horizon, with some asserting that they cannot exist while others speculate about their characteristics. The discussion remains unresolved regarding the implications of frame dragging and the conditions under which CTCs may or may not be present.
Participants reference various metrics and theoretical papers, indicating a reliance on specific mathematical frameworks and assumptions that may not be universally accepted. The discussion highlights the complexity of defining conditions for CTCs and their relationship with horizons.
Imax
Can frame dragging around a black hole induce closed timelike curves (CTC)?
Short answer: no. It would require a black hole rotating so fast that the horizon is eliminated, which can't happen.
I'm just speculating about the possibility of a CTC outside the event horizon. What could a distant observer see?
Within a CTC, causality is lost. Cause and effect do not necessarily follow. A test particle can undergo a colision, but the effects of that colision could be seen in the past, before the colision happened.
The effects of any CTC within the event horizon of a black hole is not observable to a distant observer, but a CTC outside the event horizon should have some observable characteristics.
I know. It can't be done.
Imax said:
The possibility of a CTC within a spacetime is not necessarily a bad thing. see
http://arxiv.org/PS_cache/gr-qc/pdf/0609/0609054v5.pdf
That, um, has no relevance to my point. There still aren't any closed time-like curves near the outside of the event horizon of a black hole, rotating or no.
Sorry. I don’t mean to imply that there are CTCs outside the event horizon, but frame dragging seems to be generally associated with CTCs and there seems to be very few examples of metrics which:
1) have CTCs, and
2) are generally accepted as being physically meaningful (i.e. excluding ones like the Gödel metric).
In many metrics with CTCs, such as those with frame dragging, the CTCs seem to be hidden behind a horizon. Is this a general property of these types of metrics (i.e. CTCs are hidden behind a horizon) or are there assumptions made in constructing physically meaningful manifolds that makes this necessarily the case?
For example, if you what time to go from –infinity to +infinity, then you need to construct a manifold with two properties:
1) Time orientability
2) Global hyperbolicity
Do these properties make it so that CTCs are necessarily hidden behind horizons? Global hyperbolicity implies that there are no possible CTCs (but they sometimes creep in, like in the Kerr metric).
I believe this is the case, yes.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 22 ·
