Differentiating Base, Emitter, and Collector in Transistors
  • Thread starter Thread starter amaresh92
    Base
The discussion focuses on the differences between the base, emitter, and collector in transistors, specifically examining a PNP transistor. Participants explore the roles and functions of each component within the context of transistor operation.
  • Homework-related
  • One participant describes the base as controlling the collector and emitter, likening it to a flood gate that accepts a small amount of current.
  • The same participant characterizes the collector as the part that collects the current to be controlled, while the emitter is described as the part that releases the current.
  • A metaphor is used to illustrate these roles, comparing the base to a door, the collector to an inlet, and the emitter to an outlet.
  • Another participant raises a question about identifying the three doped semiconductors in a practical scenario.
Participants generally agree on the roles of the base, emitter, and collector, but the discussion remains unresolved regarding how to identify these components in practice.
There are limitations in the discussion regarding the identification of the components based on doping and semiconductor properties, which remain unaddressed.
amaresh92
greetings,
what are the differences between base,emitter and collector?
thanks.
Lets examine a PNP transistor.
The base is what controls the collector and the emitter, i.e. it acts as a flood gate and accepts only a tiny amount of current.
the collector is the part that collects the current you want to control.
The emitter is the part that releases the current you want to control.
Imagine a door choking a river, the base would be the door, the collector the inlet, and the emitter the outlet.
thanks.
suppose we have three doped semiconductor,then how we can understand which one is what?
I call homework.
  • · Replies 23 ·
