Register to reply
Question about neutrino oscillations
by McLaren Rulez
Tags: neutrino, oscillations
Share this thread:
McLaren Rulez
#1
Jul30-11, 11:30 AM
P: 261
Hi.
I'm a college undergrad (junior year, so basic knowledge of QM but not much else) and I'm reading up on neutrino oscillations. I have a few questions.
For neutrinos, which is more fundamental: The mass eigenstates or the flavour eigenstates? In this paper http://www2.warwick.ac.uk/fac/sci/ph...35/bkayser.pdf the author says, "Suppose that there are N physical neutrinos (mass eigenstates), [itex]\nu_{m}[/itex]..." So do the mass eigenstates represent physical particles which come together in different linear combinations to produce flavour? I am a bit confused about this issue.
Also, in the same paper, the author mentions in the first page, on the right side column: In the standard treatment it is supposed that we have a beam of neutrinos all having a common fixed momentum, [itex]p_{\mu}[/itex]. So when he talks about momentum, is he saying that all the different mass eigenstates have the same momentum? If so, why is it valid to assume that they all have a fixed common momentum? Why can't different mass eigenstates have different momenta?
Thank you very much for your help.
Phys.Org News Partner Physics news on Phys.org
Physicists unlock nature of high-temperature superconductivity
Serial time-encoded amplified microscopy for ultrafast imaging based on multi-wavelength laser
Measuring the smallest magnets: Physicists measured magnetic interactions between single electrons
Parlyne
#2
Jul31-11, 05:56 AM
P: 546
I'm afraid you may not like this answer; but, which set of states are more fundamental depends on what you mean by "fundamental." If you're asking about which set of state are more reasonable to think of as the "actual physical states," the best answer is the mass eigenstates; but, if you're asking which should show up in the simplest (or, pretty much equivalently, most symmetric) description of the theory, the answer is the flavor states.
McLaren Rulez
#3
Jul31-11, 10:02 AM
P: 261
Thank you for the reply, Parlyne.
Regarding the second part, do you know why it is ok to think of a beam of mass eigenstates all having the same momentum as the standard treatment for neutrino oscillations? I also see some other sources where they treat the energy of all the eigenstates as equal instead. Why are we allowed to do this?
Thank you.
jtbell
#4
Jul31-11, 12:36 PM
Mentor
jtbell's Avatar
P: 11,619
Quote Quote by McLaren Rulez View Post
The neutrino masses are assumed to be much smaller (on the order of 1 eV/c^2) than the neutrino energies in oscillation situations: on the order of 1 MeV for solar neutrinos, and ranging up to the GeV range for accelerator experiments. In these sitations the energy equals the momentum, for all practical purposes, and changing the mass has practically no effect on the momentum, for a given energy.
If the neutrino masses were comparable to other particle masses, then this approximation wouldn't work; but in that case we would have observed the effects of neutrino mass a long time ago in other ways than neutrino oscillations!
Spinnor
#5
Jul31-11, 01:25 PM
P: 1,368
Quote Quote by jtbell View Post
So at what distance from the center of the sun can we expect the solar neutrinos to change into a different neutrino, if that makes sense? Or in other words, how many oscillations from the sun to the Earth?
Spinnor
#6
Jul31-11, 01:43 PM
P: 1,368
Quote Quote by Spinnor View Post
http://en.wikipedia.org/wiki/Neutrino_oscillation
"Oscillation distances, L, in modern experiments are on the order of kilometers"
Register to reply
Related Discussions
Neutrino Oscillations High Energy, Nuclear, Particle Physics 11
Neutrino oscillations High Energy, Nuclear, Particle Physics 5
Neutrino oscillations Advanced Physics Homework 1
