Solving Static Friction & Force: Limits & Calculation | Turntable Problem
  • Thread starter Thread starter Flinthill84
    Stuck
The discussion revolves around a physics problem involving static friction and centripetal force on a turntable. The scenario describes an object placed at a specific distance from the center of a turntable, with observations made at two different rotational speeds.
  • Participants explore the relationship between static friction and centripetal force, questioning how to express the centripetal force in terms of mass. There is discussion about the calculations needed for the coefficient of static friction and the significance of mass in the equations.
Participants are actively engaging with the problem, with some suggesting to use symbolic representation for mass. There is a focus on understanding the role of mass in the equations and whether it will cancel out in the calculations. No consensus has been reached on the approach to take.
Participants note the challenge of not knowing the mass of the object, which is central to solving the problem. There is an emphasis on working through the problem symbolically due to the absence of specific numerical values in the original question.
Flinthill84
problem with static friction and force
I have been working on this problem all weekend and I just can't get it!
A small object is placed 10cm from the center of a phonograph turntable. It is observed to remain on the table when it rotates at 33 1/3 rev/min but slides off when it rotates at 45 rev/min. Between what limits must the coefficient of static friction between the object and the surface of the turntable lie? Calculate the value of Fc.
I believe I found the first part of the question by taking Us=v^2/g*r for each value that it rotates. I think that I need to use the formula Fc=m*v^2/r for the second part of the problem but I have no clue how to find the mass and have looked all through my notes and physics book. Please if you could help me I would greatly appreciate it.
What is Fc ?
I believe it is the force
its centrip force
it is actually F sub c in the problem...centripetal force
yeah it is centrip force can anyone please help!
are you allowed to write Fc in term of m?
yeah I am pretty sure I am
then just go ahead with it. give the range of Fc using the range of your coefficient of static frictional.
how do I go ahead with it?? I don't know the mass
i thought you said that you were allowed to write Fc in term of m ?
Flinthill,
Just start working on the problem using a symbolical "m" for mass. If the figure is not in the original problem, this usually means it will cancel out somewhere.
Think of it as a nice aid to proove your solution: if the mass doesn't cancel out in your solution, you might be doing something wrong...
I usually only fill out the numbers once I have a general solution written out in symbols.
Greetz,
Leo
  • · Replies 42 ·
