Number of different ways, particle with E and delta_E.
  • Context: Graduate
  • Thread starter Thread starter Spinnor
    Particle
The discussion revolves around the number of different ways a particle with energy E and a small energy spread delta E can be represented using wave functions and momentum states. Participants explore the implications of excluding certain momentum states and the effects on scattering processes, focusing on both theoretical and practical aspects of wave function representation.
  • Some participants propose that a particle with energy E and a small energy spread delta E can be approximated using a large countable set of momentum states, while others argue that the states should be considered continuous.
  • There is a discussion on whether excluding high-energy states from a countable set affects the wave function, with some suggesting that excluding a measure-0 subset will not impact statistical predictions.
  • Participants question if many states can be practically considered the same state, leading to the idea that prohibiting some states may not be noticeable due to the large number of remaining states.
  • One participant raises a scenario involving scattering of a spin-less charged particle and questions whether different subsets of wave functions will scatter off a potential in the same way, and if small changes in these subsets can lead to significant variations in scattering outcomes.
  • Another participant suggests that as long as the potential is smooth, small gaps in the wave function set will not affect the scattering results, but acknowledges that artificial potentials may reveal differences.
Participants express differing views on the nature of momentum states (countable vs. continuous) and the implications of excluding certain states. The discussion remains unresolved regarding the effects of these exclusions on scattering outcomes.
Participants reference the concept of measure-0 subsets and their potential insignificance in statistical predictions, but the implications of these ideas are not fully settled. The discussion also touches on the nature of potentials and their smoothness, which may influence the results.
Spinnor
If we prepare a particle with energy E and some small spread in energy delta E then its wave function can be expanded with some large countable set of momentum states (exclude states above some very high energy)?
If we have a very large countable set of momentum states it seems we could exclude some states and still make a very good approximation for the wave function for a particle of energy E and energy spread delta E?
Thanks for any help!
Countable? Why? Continuous!
And of course, the mix of continuous states excluding some values should not cause any problems.
In a large box if we exclude very high energy don't we just need a countable set?
OK - in a large box, you have countable set. Don't dispute about order of infinity...
But I still can't see the problem? Yes, you may exclude a subset of measure 0 (or close to 0) and still get the same results of all statistical predictions.
I'm trying understand so that I might answer the question in the title, "Number of different ways, particle with E and delta_E". If I read you correctly it seems we can have many states that are for practical purposes the same state?
Sure!
If the number of possible states (number of degrees of freedom) counts - then if you prohibit some of the large number of still possible - it won't be noticeable.
In any case - prohibiting measure-0 subset won't cause any visible effects (like black lines on the spectrum)
xts said:
Sure!
Say we scatter a spin-less charged particle of energy E and energy spread delta E off a potential. Now say we have the wave function made of different subsets of the full set (minus the highest energy) of momentum states for this spin-less charged particle of energy E and energy spread delta E. Will those wave-functions of different subsets scatter off the potential the same? Can we manipulate things so that small changes in the subsets give rise to large variations in scattering?
As long as your potential is smooth and 'nice' small gaps in a set constituting your wavefunction have no effect. You may create artificial potentials, e.g. forming diffraction grid, differentiating small (but still finite) variances in your wavefunction. But even then, if the eliminated subset has measure of 0, they won't affect final outcome.
  • · Replies 75 ·
  • · Replies 67 ·
