Is Heat or Cold Insulation More Energy Consuming?
  • Context: Undergrad
  • Thread starter Thread starter chienphong
    Cold Heat Insulation
The discussion revolves around the energy consumption associated with heat and cold insulation, specifically whether it is more energy-consuming to maintain heat or cold protection. Participants explore a hypothetical scenario involving a cube with air insulation and varying external temperatures, aiming to understand the implications of heat flow direction on energy consumption.
  • One participant questions whether it is more difficult and energy-consuming to protect against heat or cold, using a specific example of a cube with air insulation.
  • Another participant suggests that the temperature inside the cube after one hour would be 15 degrees Celsius, indicating that the direction of heat flow does not typically matter.
  • A participant notes that air conditioners consume more power for heating than for cooling, prompting a discussion about whether this is due to different technologies.
  • One participant provides a mathematical explanation involving Newton's law of cooling, asserting that the rate of thermal energy transfer is proportional to the temperature difference between the cube and its environment.
  • The same participant emphasizes that the direction of heat transfer does not affect the magnitude of energy transfer, as it is independent of the chosen reference frame.
Participants express differing views on the implications of heat flow direction and energy consumption, with some agreeing on the temperature outcome while others question the initial assumptions and interpretations. The discussion remains unresolved regarding the broader implications of energy consumption for heating versus cooling.
Participants reference specific mathematical models and equations related to thermal energy transfer, but there are unresolved assumptions regarding the applicability of these models to real-world scenarios.
chienphong
Hi, guys!
(I created the same thread in the Engineering topic nearly a week ago but there has been no response. So I decided to move it here. Thanks.)
A few friends and I just had a discussion regarding heat and cold protection in general. Then came across a question of whether it is more difficult and energy consuming for heat protection or for cold protection, or is it the same. Let's take an example. We have a void cube (with air inside) of a certain peripheral insulation material. Let's say that we somehow adjust the inside temperature of the cube at 10 degrees Celsius and put the cube in a constant air (same type of air as in the cube) environment of 30 degrees Celsius and after 1 hour the temperature inside the cube is 15 degrees Celsius. The question is: if we adjust the inside temperature of the cube at 20 degrees Celsius and put the cube in a constant air (same type of air as in the cube) environment of 0 degree Celsius, what is the temperature inside the cube after 1 hour? Would it be 15 degress Celsius? or higher? or lower?
I would really appreciate the answer and full back up knowledge for that. Thanks a lot!
Science news on Phys.org
Welcome to PF.
15C. So the answer to the general question is no, the direction of heat flow doesn't typically matter.
Thanks a lot Russ!
However, a little more explanation and few examples would be much appreciated.
I would bring up an example here. The specifications of the air conditioners we are using show that they consume pretty much more power for heating than for cooling. Is it then just a matter of different technologies?
Thanks.
[STRIKE]I don't think that's quite right.[/STRIKE] never-mind, I used the wrong givens. See http://en.wikipedia.org/wiki/Newton's_law_of_cooling#Equations_.28Newton.27s_law_of_cooling.29". You are however correct that the direction doesn't matter.
In short, the rate of transfer of thermal energy should be proportional to the temperature difference between the cube and environment. It is described by a differential equation:
T'(t) = k(T(t)-Tenv)
Solving (brush up on your diff eqs http://tutorial.math.lamar.edu/Classes/DE/Linear.aspx" ):
T(t)=Tenv+[itex]\Delta[/itex]T*ek*t
To solve the above:
Tenv = 30o; [itex]\Delta[/itex]T = -20o
T(0)=10o
T(1hr)=15o=30o + (-20o)ek(1)
3/4 = ek
ln .75 = k
k = -.288
And the second part, plugging in k:
Tenv = 0o; [itex]\Delta[/itex]T = 20o
T(0) = 20o
T(t) = 0o + 20oe-.288t
T(1) = 20oe-.288(1) = 15o
If you can understand that equation, it should answer all of your questions. In short, direction doesn't matter because there is no privileged frame of reference. Say we were transferring heat between two boxes, one hot, one cold; the rate is not dependent which box we choose as the reference frame (the direction depends on reference frame, but not magnitude)
Thanks a lot, FireStorm!
The equation explains it and it is easy to understand. Great help.
  • · Replies 23 ·
  • · Replies 35 ·
  • · Replies 35 ·
  • · Replies 27 ·
  • · Replies 19 ·
