Questions on Take-Home Quiz (No Calculator)
  • Thread starter Thread starter kreil
    Calculator Quiz
The discussion revolves around a take-home quiz involving calculus concepts, including rates of change related to the volume and surface area of a sphere, as well as the tangent line and inverse functions of a given function. Participants are exploring various problems that require differentiation and approximation techniques without the use of calculators.
  • Mixed
  • Participants discuss the rates of change of volume and surface area of a sphere, questioning the application of the chain rule and the interpretation of derivatives.
  • There is exploration of finding the inverse of a function, with participants attempting to manipulate equations to isolate variables.
  • Another problem involves implicit differentiation and the approximation of values using tangent lines, with participants expressing uncertainty about their calculations and the correctness of their derived equations.
Some participants have provided guidance on the correct application of differentiation rules, particularly regarding the chain rule. There is ongoing exploration of the inverse function, with suggestions on how to manipulate the equation to find the desired variable. Multiple interpretations of the problems are being discussed, and participants are actively seeking clarification on their approaches.
Participants are constrained by the requirement to solve problems without calculators, which adds complexity to their calculations and approximations. There is also mention of a lack of prior instruction on certain topics, which may affect their confidence in solving the problems.
kreil
Insights Author
I have a couple questions about some problems on a take-home quiz that I got (no calculator allowed) Bear with me, this post is long...
1. The radius (r) of a sphere is increasing at a constant rate of 0.04 cm/s. (Note: The volume of a sphere with radius r is V=4/3pir³
a) At the time when the radius of the sphere is 10 cm, what is the rate of increase of its volume?
b) At the time when the volume of the sphere is 36pi cubic cm, what is the rate of increase of the area of a cross section through the center of the sphere?
c) At the time when the volume and the radius of the sphere are increasing at the same numerical rate, what is the radius?
I had no problems with parts a or b:
a)V'=4pir²
V'(10)=4pi100
=400pi cubic cm/s
b)36pi=4/3pir³
27pi=pir³
r=3
A=pir²
A'=2pir
A'(3)=2(pi)(3)
=6pi cm/s
c) This is the one I was unsure about...What I did here was set the rate of increase of the radius (0.04) equal to the rate of increase of the volume of the sphere (4pir²) and solve for r, but for some reason it doesn't feel right:
(4)(10^-2)=4pir²
r²=.1/pi
r=(.1/pi)^(1/2)
Did I do this part correctly or not?
2. Let f be the function defined by f(x)=(1+tanx)^(3/2) for -pi/4 <= x < pi/2
a) Write an equation for the line tangent to the graph of f at the point where x=o
b) Using the equation found in part a, approximate f(0.02)
c) Let f^-1 denote the inverse fcn of f. Write an expression that gives
f^-1(x) for all x in the domain of f^-1.
Once again, no problems with a or b:
a) f'(x)=3/2(1+tanx)^1/2 (sec^2(x))
f'(0)=3/2(1+0)^1/2 (sec^2(0))
f'(0)=3/2(1)(1)
f'(0)=3/2
f(0)=1
(y-1)=3/2(x)
b) f(x)=(3/2)x+1
f(0.02)=(3/2)(2)(10^-2)+1
f(0.02)=.03+1
f(0.02)=1.03
c) I THINK all it asks for here is the inverse function of f...but it seems like there are too many conditions for the answer to just be
f^-1(x)=(1+tany)^(3/2) <~ is this correct?
Thank you in advance for all help offered.
a)V'=4pir²
V'(10)=4pi100
=400pi cubic cm/s
Actually you DO have a problem with parts a) and b). What you have found here is dV/dr. The "rate of increase of volume" is dV/dt. Use the chain rule:
dV/dt= (dV/dr)(dr/dt) and you are given dr/dt.
b)36pi=4/3pir³
27pi=pir³
r=3
A=pir²
A'=2pir
A'(3)=2(pi)(3)
=6pi cm/s
Same thing. A'= dA/dr is NOT the "rate of increase of the area". That is
dA/dt= (dA/dr)(dr/dt).
(4)(10^-2)=4pir²
r²=.1/pi
r=(.1/pi)^(1/2)
Once again, the "rate of change of the volume" is NOT dV/dr: it is
dV/dt= (dV/dr)(dr/dt). If (dV/dr)(dr/dt)= dr/dt, what do that tell you about dV/dr??
f'(0)=3/2(1)(1)
f'(0)=3/2
f(0)=1
(y-1)=3/2(x)
b) f(x)=(3/2)x+1
f(0.02)=.03+1
f(0.02)=1.03
Yes, those are correct.
Look carefully at your answer! You have f-1(x) on one side (the independent variable is x) but there is no x on the other side of the equation! In fact, all you did is replace "x" by "y"!
What you were vaguely remembering, I suspect, is this: rewrite the equation as y= (1+ tan(x))3/2 (just replace "f(x)" by y).
Now, SWAP x and y: x= (1+ tan(y))3/2. That's what really gives the "inverse" function: f goes "from x to y" and the inverse function reverses that. In order write this as a function, however, you now have to solve for y.
My teacher just informed me today that we haven't learned how to do #1 yet...I guess that explains why I totally blew it.
As to the inverse question...how do you propose that I solve for y in
x=(1+tany)^3/2 ?
Expanding the expression seems to get me nowhere.
Thanks for your help!
Start by raising each side to the power of 2/3.
--J
Does this work?
x=(1+tany)^3/2
1.raise each side to the 2/3:
x^2/3 -1=tany
2. Multiply each side by cot(y):
y=(x^2/3 -1)cot(y)
Thanks for the hint
Keep in mind that tan(y)*cot(y) = 1, not y. Also, arctan(tan(y)) = y.
--J
Ok, so...
x^2/3 -1=tany
arctan(tan(y))=arctan(x^2/3 -1)
y=arctan(x^2/3 -1)
Check:
f^-1(f(x))=arctan(((1+tanx)^(3/2))^2/3)-1)=arctan(1+tanx-1)=arctan(tanx)=x
f(f^-1(x))=(1+tan(arctan(x^2/3 -1)))^(3/2)=(1+x^3/2-1)^2/3=x
Thanks Justin!
Different problem, same take home quiz...
Consider the curve defined by: -8x^2 + 5xy + y^3 = -149
a)find dy/dx
b)write an equation for the line tangent to the curve at the point (4,-1)
c)There is a number k so that the point (4.2, k) is on the curve. Using the tangent line found in part b, approximate the value of k.
d)write an equation that can be solved to find the actual value of k so that the point (4.2, k) is on the curve.
e)solve the equation found in part b for the value of k
still no calculator.
I solved parts a,b, and c. If it matters, the approximation I found for k in part c was -0.4. On part d, I substituted the point in the equation:
-8(4.2^2) + 5(4.2)(k) + k^3 = -149
-141.12 + 21k + k^3 = -149
k^3 + 21k + 7.88 = 0
And so my problem is part e. I cannot graph it since I am not allowed to use a calculator,and I am pretty sure this will not factor. It is not a quadratic so I cannot use quadratic formula. Of course, it is entirely possible my equation from part d is wrong...
What does everyone think? All hints/suggestions/thoughts welcome.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 32 ·
