How Is Volume Calculated Using Cylindrical Shells?
This discussion focuses on calculating volumes using cylindrical shells through definite integration. The participants verify solutions for various problems involving curves and solids of revolution, applying the formula V = 2π∫(radius)*(height)dx. Key problems include finding volumes for regions bounded by specific curves and lines, with solutions provided for cases involving y=1/x^3 and y=1/(1+x^4). The discussion also highlights the need for careful handling of integrals to avoid undefined expressions.
  • Understanding of definite integration techniques
  • Familiarity with cylindrical shell method for volume calculation
  • Knowledge of limits and their application in calculus
  • Ability to perform u-substitution in integrals
  • Learn how to apply the cylindrical shell method to various geometric shapes
  • Study the implications of limits in volume calculations, particularly with infinite bounds
  • Explore u-substitution techniques for simplifying complex integrals
  • Investigate the relationship between cross-sectional areas and volume in solids of revolution
Students and educators in calculus, particularly those focusing on volume calculations using integration techniques, as well as mathematicians interested in solid geometry and applications of definite integrals.
Bri
Hi, I was hoping someone could check my work on a few problems and get me started on a few others. It involves definite integration, so I'm going to use (a,b)S as an integration symbol and P for pi.
These are the ones I need checked:
1. Use cylindrical shells to find the volume of the solid generated when the region enclosed by the given curves is revolved about the x-axis.
x=2y, y=2, y=3, x=0
2P*(2,3)Sy(2y)dy = 4P*(2,3)S(y^2)dy = 4P/3*[y^3](2,3) = 76P/3
2. Use cylindrical shells to find the volume of the solid that is generated when the region that is enclosed by y=1/x^3, x=1, x=2, y=0 is revolved about the line x=-1
2P*(1,2)S(x/(x-1)^3) = -2P*[(1-2x)/(2(x-1)^2)](1,2) =
I'm stuck here, because putting 1 into the equation puts a zero in the denominator.
3. (a) Find the volume V of the solid generated when the region bounded by y=1/(1+x^4), y=0, x=1, and x=b (b>1) is revolved about the y-axis.
(b) Find lim(b->+infinity) V
(a) 2P*(1,b)S(x/(1+x^4)) = 2P*[(x^2)/2 - 1/(2x^2)](1,b) = 2P(.5b^2 - 1/(2b^2))
(b) Infinity
4. The base of a certain solid is the region enclosed by y = x^.5, y=0, and x=4. Every cross section pependicular to the x-axis is a semicircle with its diameter across the base. Find the volume of the solid.
P/16*(0,4)Sxdx = .5P
These are the ones where I don't even know where to start:
5. The region enclosed between the curve y^2=kx and the line x=.25k is revolved about the line x=.5k. Use cylindrical shells to find the volume of the resulting solid. (Assume k>0)
6. Use cylindrical shells to find the volume of the torus obtained by revolving the circle x^2 + y^2 = a^2 about the line x=b, where b>a>0. [Hint: It may help in the integration to think of an integral as an area.]
Much thanks to anyone who can give me any help. I really appreciate it.
Hi Bri,
The first one looks good, but that's all I have had time to look at. I am an old lady and very slow! :smile: And it's been a while since I've done any shelling!
I am hoping this post will inspire some others to jump in.
Hi there,
I will be happy to check your work and provide guidance on the problems you are stuck on.
1. Your work for this problem looks good. You correctly used the formula V = 2π∫(radius)*(height)dx and found the volume to be 76π/3.
2. For this problem, you are correct in using the formula V = 2π∫(radius)*(height)dx. However, when you substitute in the values, you get a zero in the denominator. This is because the curve y=1/x^3 intersects the y-axis at (0,∞). Therefore, you need to split the integral into two parts: from 1 to a small number (such as 0.1) and from the small number to 2. This will give you two separate integrals that you can evaluate. The final answer should be 2π/3.
3. Your work for part (a) is correct. For part (b), you are correct that the limit as b approaches infinity is infinity. However, you should also note that as b approaches infinity, the term 1/(2b^2) approaches 0. Therefore, the final answer is infinity.
4. For this problem, you need to use the formula V = π∫(radius)^2dx. The radius of each semicircle is given by y = x^(1/2), so the integral becomes π∫(x^(1/2))^2dx. Evaluating this integral from 0 to 4 gives a final answer of 8π/3.
5. For this problem, you will need to use the formula V = 2π∫(radius)*(height)dx. The radius is given by x = y^2/k, so the integral becomes 2π∫(y^4/k)*(y)dy. You will need to use u-substitution to solve this integral. Once you have the integral set up, you can evaluate it from y = 0 to y = √(kx). The final answer should be 2πk^2/15.
6. For this problem, you will need to use the formula V = 2π∫(radius)*(height)dx. The radius is given by x = √(a^2-y^2), so the integral becomes 2π∫(√(
  • · Replies 18 ·
  • · Replies 18 ·
