Addition of exponentials, and relationship between variables.
The discussion revolves around the relationship between the variables w and q in the context of an equation involving exponentials. The original poster has already solved the problem but seeks to explore alternative methods for deriving the relationship.
  • Participants discuss the geometric interpretation of the exponentials as vectors in the complex plane and consider the implications of their magnitudes and angles. There is also a consideration of the conditions under which the sum of the exponentials equals -2.
Some participants have provided insights into the geometric aspects of the problem and the conditions required for the exponentials to sum to -2. The conversation is ongoing, with participants exploring different interpretations and implications of the relationships between w and q.
There is a mention of the possibility that q and w could be imaginary, which may lead to additional solutions. The original poster's constraints regarding m and n being positive integers are also noted.
Animastryfe
This is, strictly speaking, not a homework question. I have already solved this, but I think that there is a much better method to solve it.
In the equation below, what relationship must w and q satisfy? If the question is not clear, please read the bottom of the post.
Exp[-i*q*t]+Exp[-i*w*t]=-2
I turned everything into cosines and sines, and used the trigonometric sum to product formulas.
In case the question isn't clear, the answer is w/q= (2m-1)/(2n-1), where m and n are positive integers and not equal to each other.
Hi Animastryfe! :smile:
Assuming q and w are real numbers, the two exponentials each correspond to a vector with length 1 and angle -qt respectively -wt.
This is the polar coordinate representation of a complex number.
To get them to have sum -2, both the exponentials must come out as -1.
This means that -qt = pi mod 2pi and that -wt = pi mod 2pi.
Divide them on each other and you get the result you have.
However, if q and w can be imaginary as well, you get a lot more solutions! :wink:
Thank you. I should think more geometrically.
Please note that, in general, for two complex numbers to add to -2, they do not have be each be -1. Here, however, each has magnitude 1 so in terms of a vector addition, we have a "triangle" with two sides of length 1 and the third of length 2. That, of course, is impossible except in the very special case that the "triangle" is really a straight line.
