Solve Physics Problem: Target 120 m Away, Speed 250m/s
  • Thread starter Thread starter kashmirekat
The physics problem involves calculating the vertical drop of a bullet fired horizontally at a target 120 meters away with an initial speed of 250 m/s. The bullet experiences gravitational acceleration of -9.8 m/s², leading to a vertical displacement calculated using the equation Δy = 0.5 * a * t². After determining the time of flight as 0.48 seconds, the bullet drops 1.12 meters, resulting in a miss of the target by this distance. The key equations used are for horizontal and vertical displacement.
  • Understanding of kinematic equations
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Familiarity with horizontal and vertical motion concepts
  • Ability to perform basic algebraic manipulations
  • Study kinematic equations for projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore advanced topics in ballistics and trajectory analysis
  • Investigate real-world applications of physics in shooting sports
Physics students, educators, and enthusiasts interested in understanding projectile motion and its applications in real-world scenarios such as hunting and sports shooting.
kashmirekat
The question says that a hunter aims directly at a target (on the same level) 120 m away. If the bullet leaves the gun at a speed of 250m/s, by how much will it miss the target?
So my values are v_o=250m/s, r=120m, and angle=0 since they're on the same level, right? And I need to know v to subtract from 120m.
I would just like to know what equation to use, not the answer to the problem. Thank you.
The acceleration downward is 9.8 m/s2 so dv/dt= -9.8.
Integrating (or, since this is a constant, just mutiplying)
v= -9.8t+ initial vertical velocity= -9.8t+ 0 so v= dy/dt= -9.8t.
Integrating that, y= -4.9t2+ initial height= -4.9t2.
Neglecting air resistance (which we have to since there is no information on air resistance) there is no horizontal acceleration:
a= dv/dt= 0 so v= initial horizontal velocity= 250 m/s. and then
x= 250t. To go 120 m, requires that 250t= 120. Solve that equation for t and use that t in y= -4.9t2 to find how much the bullet has dropped.
To solve this physics problem, we can use the equation for horizontal displacement:
Δx = v_o * t
Where Δx is the horizontal displacement, v_o is the initial velocity, and t is the time.
In this case, we know that the initial velocity is 250m/s and the horizontal displacement is 120m. We can rearrange the equation to solve for t:
t = Δx / v_o
Plugging in the values, we get:
t = 120m / 250m/s = 0.48s
Now, we can use the equation for vertical displacement to find the vertical distance the bullet will travel during this time:
Δy = v_o * t + 0.5 * a * t^2
Where Δy is the vertical displacement, v_o is the initial velocity, t is the time, and a is the acceleration (which we can assume to be -9.8m/s^2 for simplicity).
Since we know that the initial vertical velocity is 0m/s (since the bullet is fired horizontally), we can simplify the equation to:
Δy = 0.5 * a * t^2
Δy = 0.5 * (-9.8m/s^2) * (0.48s)^2 = -1.12m
Therefore, the bullet will miss the target by 1.12m. This is because while the bullet is traveling horizontally for 0.48s, it is also falling vertically due to gravity.
I hope this helps and provides you with the necessary equation to solve the problem. Remember to always pay attention to the units and use the appropriate equations for the given situation.
  • · Replies 17 ·
15K
  • · Replies 22 ·
