Concept Check for two Green Theorems Problems
  • Thread starter Thread starter stratusfactio
    Concept Green
This discussion focuses on the application of Green's Theorem to evaluate two line integrals. The first problem involves the integral of the function \( C(e^{x^2} + y^2) \, dx + (e^{y^2} + x^2) \, dy \) around a triangular path, yielding a result of 0 after applying the theorem correctly. The second problem, involving the integral \( C(e^x \sin y) \, dx + (y^3 + e^x \cos y) \, dy \) around a rectangular path, also results in 0, confirming the correctness of the approach. The key takeaway is the importance of correctly setting the limits of integration, particularly in the first problem where the diagonal of the triangle is defined by the line \( 4 - y \).
  • Understanding of Green's Theorem
  • Knowledge of line integrals and double integrals
  • Familiarity with partial derivatives
  • Basic geometry of triangles and rectangles in the Cartesian plane
  • Study the application of Green's Theorem in different geometrical contexts
  • Learn about the divergence theorem and its relationship to Green's Theorem
  • Explore examples of line integrals in polar coordinates
  • Practice solving more complex line integrals involving parametric curves
Students studying multivariable calculus, particularly those focusing on vector calculus and line integrals, as well as educators seeking to clarify the application of Green's Theorem in practical problems.
stratusfactio
**The book I'm working from doesn't have solutions for even numbered problems and the two problems I'm about to show you guys are even, so if you guys don't mind, I would just like to know if I have the right concept, or if I messed up anywhere. I wouldn't have a way of knowing since there aren't answers for the two problems in the back of the book.**
For the following problems use Green’s Theorem to evaluate the given line integral around the
curve C, traversed counterclockwise.
1. Closed integral of C(e^(x^2)+ y^2) dx + (e^(y^2)+ x^2) dy; C is the boundary of the triangle with vertices (0,0),(4, 0) and (0, 4)
2. Evaluate closed integral of C (e^x sin y) dx + (y^3 + e^x cos y) dy, where C is the boundary of the rectangle with vertices (1, −1), (1, 1), (−1, 1) and (−1, −1), traversed counterclockwise.
[1] I got 0 for the answer. We see that P = e^(x^2)+ y^2 and Q = e^(y^2)+ x^2, so taking derivative of Q w/ respect to x we obtain 2x and taking derivative of P w/ respect to y we obtain 2y. Therefore we have the double integral w/ both integrands ranging from [0,4] of 2x - 2y.
[2] I got 0 for the answer here also. We see that P = e^x sin y and Q = y^3 + e^x cos y, so taking derivative of Q w/ respect to x we obtain e^x cos y and taking derivative of P w/ respect to y we obtain e^x cos y as well. Therefore we have the double integral w/ both integrands ranging from [-1,1] of e^x cos y - e^x cos y ( or 0 and therefore answer is 0).
Your answers are correct but in the first problem your int dx should run from 0 to 4-y. It came out the same this time, however.
Ahhh, I see. Is that because the diagonal of the triangle is the line 4-y?
  • · Replies 18 ·
