Escape velocity from center of earth
The discussion revolves around calculating the escape velocity of an object from the center of the Earth. Participants explore the theoretical framework, mathematical approaches, and the implications of gravitational forces and potential energy in this context.
  • One participant suggests that escape velocity from the center can be derived by adding the velocity needed to reach the surface to the escape velocity from the surface, proposing a formula of 2sqrt[2gRe).
  • Another participant counters that it is the energies that add, not the velocities, and recommends calculating potential energy by integrating the gravitational force from the center to infinity.
  • There is a discussion about the correct limits of integration for calculating potential energy, with some participants indicating that the force of gravity changes from the center to the surface and then to infinity.
  • A participant expresses confusion about how the integral of gravitational force relates to escape velocity, questioning whether it reflects the work done by gravity.
  • One participant calculates potential energy as -2mgRe and equates it to kinetic energy to derive a velocity, but questions the validity of their assumptions given that this value exceeds the escape velocity from the surface.
  • Another participant corrects the first integral's force, stating that at the center of the Earth, the force is zero, and emphasizes the need for a proper understanding of gravitational force using Gauss' law.
  • A later reply raises a concern about the implications of having zero potential energy at the center, suggesting that this could lead to contradictions regarding escape velocity being infinite or zero.
  • Another participant clarifies that while potential energy is zero at infinity, what matters is the difference in potential energy between the center of the Earth and infinity.
Participants express differing views on the correct method to calculate escape velocity from the center of the Earth, with no consensus reached on the validity of the proposed approaches or calculations.
There are unresolved issues regarding the assumptions made in the calculations, particularly concerning the nature of gravitational force at different points within the Earth and the reference points for potential energy.
Torquenstein101
How would one go about calculating the escape velocity of an object with mass m from the center of the Earth. I understand that that when launched from the surface of the Earth, mechanical energy is conserved and you end up with v escape =sqrt[2gRe] So what i did was i calculated what i thought was the velocitiy it takes to get from the center of the Earth to the surface of the Earth and then add the escape velocity from the surface of the Earth to that. I then got 2sqrt[2gRe)]. Is this right? Can someone put me on the right track?
It's the energies that add, not the velocities. Simply calculate the potential energy at the centre of the earth, referenced to infinity being at zero potential energy. You can do this by integrating the force of gravity from the centre to infinity. This integral will split into two parts: from the centre to the surface, the force is proportional to r, and from the surface to infinity, it is proportional to 1/r^2.
hey thanks, so the integral would contain [(-GMem)/r]dr with limits of integration being Re and Infinity? I guess i have a hard time seeing why this would give me the escape speed from the center of the earth...Wouldnt taking the integral of the Force of gravity show how much work is being done by gravity?
No. As krab stated you need to integrate the gravitational force from zero to infinity. Do it in steps: from center to surface, then from surface to infinity.
Right. That will tell you how much KE you need to overcome the work done by gravity.
Ok, so my first integral would be [tex]\int (-mg) dr[/tex] with limits of integration being 0 to Re. I add this to the second integral which is [tex]\int (-GMem/r^2) dr[/tex] with limits of integration being from Re to [tex]\infty[/tex].
So, my total potential energy would be -2mgRe.
So at the Center of the Earth, the initial kinetic energy is (1/2)mv^2. So, conserving mechanical energy, i have (1/2)mv^2 = 2mgRe. Solving for v, i get 2 sqrt(gRe). Are my assumptions correct? I do notice that this value is greater than the escape velocity starting from the surface of the Earth. Does this value look correct?
Thanks a lot guys for helping me out.
No. The force is not mg in the first integral. It couldn't be. For example at the centre of the earth, the force is zero. In fact, the force is mgr/R. If you know Gauss' law, you can prove why this is so.
BTW, the tex in square brackets that closes the code is preceded by a forward slash, not a backslash.
(sorry for reviving an old thread)
I don't understand how we can calculate the escape velocity from the center of the earth.
If at the center of the earth, you have 0 potential energy, then you would find that the escape velocity would be infinite, or 0, depending on the formulae used.
Generally, the potential energy is taken to be zero at infinity. But that's just a reference point. What matters is the difference in potential energy between the center of the Earth and infinity, which is neither zero nor infinite.
  • · Replies 27 ·
10K
