Register to reply
Heat moving through the walls of a house
by Punkyc7
Tags: heat, house, moving, walls
Share this thread:
Punkyc7
#1
Aug4-11, 12:37 AM
P: 420
A carpenter builds an exterior house wall with a layer of wood 3.2 {\rm cm} thick on the outside and a layer of Styrofoam insulation 2.4 cm thick on the inside wall surface. The wood has k=0.080 W/(m* K, and the Styrofoam has k= 0.010 W/ m* K)}. The interior surface temperature is 20.0C, and the exterior surface temperature is -12.0C.
What is the temperature at the plane where the wood meets the Styrofoam?
so i set up
H=Ak(Tf-T0)/L
H=Ak(Tf-T0)/L
set them both equal so the A drops out
.08(x-20)/.o32=.01(x+12)/.024
and get 26.4 which is wrong, so where am i going wrong at?
Phys.Org News Partner Science news on Phys.org
Flapping baby birds give clues to origin of flight
Prions can trigger 'stuck' wine fermentations, researchers find
Socially-assistive robots help kids with autism learn by providing personalized prompts
PeterO
#2
Aug4-11, 03:21 AM
HW Helper
P: 2,318
Quote Quote by Punkyc7 View Post
so i set up
H=Ak(Tf-T0)/L
H=Ak(Tf-T0)/L
Your temperature difference on the LHS is wrong way round.
x will be between 20 and -12, so the temp differences should be 20 - T, and T - (-12)
Hopefully that fixes it up.
Register to reply
Related Discussions
Liquid moving up a containers walls... Chemistry 4
Heat Loss Through Walls Introductory Physics Homework 0
Mineral buildup in heat exchanger tubing walls Materials & Chemical Engineering 1
House Color and Heat Classical Physics 8
I'm moving house! General Discussion 37
