The moment of inertia of the stool with respect to an axis at its center?
The problem involves calculating the moment of inertia of a stool composed of a solid circular disk and three thin rods attached perpendicularly at the edge of the disk. The disk has a specified mass and radius, while the rods have a known mass but their length is not provided. The focus is on determining the moment of inertia with respect to an axis at the center of the disk.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the additive nature of moment of inertia and the formulas applicable to the disk and rods. There is uncertainty about how to incorporate the mass and length of the rods into the calculations. Some participants question the relevance of the rods' length and whether they can be treated as point masses.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the treatment of the rods as point masses, but there is still confusion about the correct application of the formulas and the distances involved.
Participants note that the problem does not provide the length of the rods, leading to questions about how this affects the moment of inertia calculation. There is also a mention of a lab experience related to angular momentum that influences their reasoning.
chattkis3
Hi! I am working on this problem:
A solid circular disk has a mass of 1.2 kg and a radius of 0.17 m. Each of three identical thin rods has a mass of 0.16 kg. The rods are attached perpendicularly to the plane of the disk at its outer edge to form a three-legged stool. Find the moment of inertia of the stool with respect to an axis that is perpendicular to the plane of the disk at its center. (Hint: When considering the moment of inertia of each rod, note that all of the mass of each rod is located at the same perpendicular distance from the axis.)
Here is my thinking so far (but I am stumped!):
-Moment of Inertia's are additive
- The moment of inertia for the circular disk is (1/2)M*R^2
- I don't know how to get the moment of inertia for the three legs because they don't give me a mass. I am pretty sure the formula is 1/3M*L^2 but I don't know L ??
Thanks for the help.
Re-read the problem - the mass of the rods is stated explicitly. The length of the rods should be unimportant - perhaps you can figure out why.
Oh whoops, I didn't mean to put that the mass was not known. So it's been a couple of days and I am still stumped on why the length would not matter.
Is this close to the right track?
(1/2*M*R^2)+(1/3m)+(1/3m)+(1/3m) = I
M= mass of stool top
m = mass of one leg
The legs are parralel to the axis of rotation right? So, in the plane of rotation (perpendicular to the axis of rotation) they're essentially point masses. (Does this make sense to you?)
I get:
[tex]\frac{1}{2}MR^2 + 3 \times (\frac{R}{3})^2m[/tex]
I get:
could you please explain that for me? it would seem like the legs would matter, since there is a r (distance between them and the axis of rotation). we just covered angular momentum and i have yet to work through the homework.
thanks, if you've the time!
NateTG, why you put R/3? Since the rods can be considered as point masses on the solid disc, I think it should be mR^2 for each, right?
well from the lab on angular momentum that we did, two point particles rotating on a bar -- the moment of intertia can be calculated as
2mr^2
now that i see what he's talking about with that r/3 part, he's doing the same thing. it's like there are 3 of them adding to the moment of inertia. i don't understand what the 1/3 of R is for. it seems to me like it should be 3mR^2.
That was a brain fart. I thought the rods were [tex]\frac{1}{3}[/tex] of the radius out rather than at the edge.
  • · Replies 28 ·
  • · Replies 21 ·
