Rotational Motion: Who Reaches Bottom First?
The discussion revolves around two hoops rolling down identical inclined planes under the influence of gravity, with one hoop featuring additional mass in the form of spokes. Participants are exploring the implications of this setup on the translational and rotational kinetic energies of the hoops and how these factors influence their acceleration and time to reach the bottom.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conservation of energy and the relationship between mass distribution, moment of inertia, and speed. Questions are raised about how the additional mass affects the kinetic energies and the resulting acceleration of each hoop.
There is an active exploration of the concepts of moment of inertia and energy distribution between translational and rotational forms. Some participants are questioning assumptions about how mass affects speed and inertia, while others are attempting to clarify the implications of these factors on the hoops' motion.
Participants are navigating complexities related to the definitions of moment of inertia and the conditions under which the hoops are compared. There is mention of a previous experiment that relates to the acceleration of rolling objects, which may influence their reasoning.
justagirl
Two hoops of identical radii roll without slipping down identical inclined planes under the influence of gravity. Hoop 1 is identical to Hoop 2 except for some massive spokes which are fixed to the rim.
If the two hoops are released at the same time from the same height, which hoop makes it to the bottom of the ramp first?
Thanks!
Each hoop starts with the same amount of energy at the top of the ramp.
Which one has more translational kinetic energy at the bottom? Or, perhaps more importantly, which one has more rotational kinetic energy at the bottom, and how would this affect the translational KE?
What does this result mean for the time it takes to get to the bottom?
--J
re;
The part of I'm confused on is this:
The wheel with the spokes has more mass, which increases inertia and decreases speed. But it also has more mass concentrated around the radius, which increases speed...
What does this mean?
Consider the moment of inertia as a whole. Also remember that angular velocity (and hence angular KE) is proportional to linear velocity, i.e. the faster the wheel is moving down the ramp, the faster it's rolling.
--J
I'm a lil confused:
so by conservation of energy I have:
mgh = 1/2mv^2 + 1/2Iw^2
mgh = 1/2mv^2 + 1/2I(v^2/r^2)
V^2(1/2m + 1/2(I/R^2) = mgh
v^2 = mgh / (1/2m + 1/2(I/R^2))
For spoke one, the mass is greater, so speed decreases...
But wouldn't I be smaller? Wouldn't that increase the speed?
You've caught the important part of the problem.
If the total mass of the two hoops are equal, the wheel with the spokes has more mass towards the center and a smaller moment of inertia. It accelerates faster. (I=mr^2)
If the two hoops are identical (i.e. - they have the same amount of mass out on the rim) except one hoop has some additional mass added to it in the form of spokes, the one with the spokes has the larger moment of inertia. Technically, the moment of inertia is the sum of the moment of inertia of each piece of the hoop. So, adding mass, regardless of its placement, is adding more inertia.
In other words, read the question carefully and make sure which condition the question is talking about.
would the smaller inertia hoop be going faster or does it not matter? I think we did this experiment where we found acceleration to be g sin theta / (1 + c), where c was the constant of inertia. (i.e., 1/2 for a cylinder and 1 for a hoop).
help! can someone please answer/
The hoop with the spokes is both heavier and has a larger moment of inertia.
Suppose both hoops are going down the ramp with velocity v. Compare their total kinetic energies.
E = mv^2/2 + Iw^2/2
Note that both m and I are larger for the hoop with the spokes, so v and w must be smaller in order to achieve the same total energy.
--J
16K
