Calculating Work Done: 16.0-kg Shopping Cart at a Constant Velocity
  • Thread starter Thread starter benji
    Work Work done
The problem involves calculating the work done by various forces acting on a 16.0-kg shopping cart being pushed at a constant velocity over a distance of 22.0 m, with a frictional force of 48.0 N opposing the motion. The force is applied at an angle of 29.0 degrees below the horizontal.
  • The original poster attempts to analyze the problem using free-body diagrams and net force equations but expresses uncertainty about their approach. Some participants suggest focusing on the balance of forces due to the constant velocity condition and separating forces into components. Others emphasize the importance of correctly identifying the forces involved, including normal force and friction.
Participants are actively engaging with the problem, offering guidance on how to set up the free-body diagram and calculate the forces. There are multiple interpretations of the work done by different forces, and some participants are questioning the assumptions made regarding the direction of forces and the conditions for work calculation.
The original poster indicates a time constraint due to an upcoming class, which may influence the depth of responses and the urgency of the discussion.
benji
Alright, here's the question:
A person pushes a 16.0-kg shopping cart at a constant velocity for a distance of 22.0 m. She pushes in a direction 29.0-degrees below the horizontal. A 48.0-N frictional force opposes the motion of the cart. (a) What is the magnitude of the force that the shopper exerts? Determine the work done by (b) the pushing force, (c) the frictional force, and (d) the gravitational force.
I know this is a relatively simple problem, but I missed most of class when we were discussing this stuff. So if someone could start me off on the right foot, I'm sure I'll be able to figure it out.
What I tried so far was drawing a free-body diagram then making net force equations for the X and Y directions--but I haven't had any luck doing that. I must be missing something? Either that or I'm going about this completely the wrong way.
A timely reply is appreciated--I have class in about an hour.
Thanks!
Constant velocity suggests that there's no net force. Find the magnitude of the applied force such that this condition is met. You'll have to separate the forces into x and y components, but just remember that the normal force will adjust itself to cancel any force going into the ground. This means you'll really only need to consider the x direction.
--J
A quick reply is what your looking for so verify the information I give you as I may error in answering quickly...
Draw out your freebody diagram again and get all the values figured out for your Fx, Fy, Friction, N, mg, ect.
Looks like in this case you will have the following...
N = mg + Fy
Fx = Fcos(theta)
Fy = Fsin(theta)
W = Fd if parallel so we know that W = Fx * d or W=Fxd = Fdcos(theta)
Hopefully that will get you started. I know it is just formulas you probably already know... but...
Thanks for the help!
b)w(friction) should be force of friction*displacement..since the angle is zero
c) work done by gravity is zero because there is no up or down movement of the cart
a) F(applied)=mgcos(theta)
d) w=F(applied)*d
I think. LoL
  • · Replies 58 ·
