Solving a Forces Problem: Need Help!
  • Thread starter Thread starter DethRose
    Forces
The discussion centers on solving a torque problem related to a lever system in physics homework. The key parameters include distances A (45 cm) and B (65 cm), a pulling force of 80 N, and an angle of 30 degrees. To determine the force that prevents the lever from rotating about point 0, the torque equation (torque = force x distance x sin(angle)) is utilized. The solution involves calculating the torque at points A and B and setting them equal to maintain equilibrium.
  • Understanding of torque and rotational forces
  • Familiarity with the torque equation: torque = force x distance x sin(angle)
  • Basic knowledge of equilibrium conditions in physics
  • Ability to convert angles from degrees to radians
  • Study the concept of torque in detail, focusing on its applications in static equilibrium
  • Learn how to calculate forces in lever systems using the principles of moments
  • Explore the relationship between friction and torque in practical scenarios
  • Practice solving similar physics problems involving angles and forces
Students studying physics, particularly those preparing for tests on mechanics and torque, as well as educators looking for examples of lever problems in teaching materials.
DethRose
Forces Problem Please Help!
Ive got a question in this weeks homework that isn't in the text or anything...i think it is a torque problem but am not sure even where to start :confused:
Its a drawing but the question asks
What force will keep the lever from turning about point 0? Given A=45 cm, B=65 cm, the pull is 80 N, and angle is 30 degrees.
The drawing it just a bar with a starting on the left side, 0 being where a and b join, and an angle labled pull at the other end.
please help i have a test in 2 days haha
thanks
in advance :) Answer: The force that will keep the lever from turning about point 0 is the friction force between the lever and the surface it's resting on. The magnitude of this force depends on the coefficient of friction between the two surfaces, which is not given in the question.
Hi there,
I understand that you are struggling with a forces problem in your homework and are not sure where to start. It sounds like this problem involves torque, which is the rotational force applied to an object. To solve this problem, you will need to use the equation for torque, which is torque = force x distance.
First, you will need to identify the point of rotation, which in this case is point 0. Next, you will need to calculate the distance from point 0 to point A and point B, which are given as 45 cm and 65 cm, respectively. Then, you will need to calculate the torque created by the pull, which is 80 N, at a 30 degree angle. To do this, you can use the formula torque = force x distance x sin(angle). Make sure to convert the angle to radians if necessary.
Once you have calculated the torque at both points A and B, you can set them equal to each other since the lever is in equilibrium (not turning). This will give you an equation that you can solve for the missing force. Remember to use the correct units (N for force and cm for distance) in your calculations.
I hope this helps you get started on solving the problem. Don't hesitate to reach out if you need further clarification. Best of luck on your test!
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 16 ·
