How Do I Set Up the Schrodinger Equation for This Wave Function?
  • Thread starter Thread starter apigban
The discussion revolves around setting up the Schrödinger equation for a particle described by the wave function Ψ = A sinh(x). Participants are exploring the implications of using different forms of the wave function, specifically the hyperbolic versus exponential forms, and addressing normalization concerns.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the necessity of using the exponential form of the hyperbolic function for the Schrödinger equation. Questions arise regarding the normalization of the wave function and the treatment of the complex conjugate, particularly since the function appears real-valued.
The conversation is ongoing, with some participants providing guidance on normalization and integration. There is acknowledgment of different approaches to the wave function's form, but no consensus has been reached regarding the best method for normalization or the implications of using one form over the other.
Participants are navigating the complexities of the Schrödinger equation, including potential energy considerations and the limits of integration for normalization. There is a recognition of the need for clarity on these topics, but specific details remain under discussion.
apigban
Hi! I am having some problems in setting up the Schrödinger equation for a particle described by the wave function:
[itex]\Psi[/itex] = A sinh (x)
should I use the exponential form of the hyperbolic function?
[URL]http://62.0.5.135/upload.wikimedia.org/math/9/c/7/9c74b71126c6bb1f4d6b865019a2735e.png[/URL]
Also, for normalization, do you have any guides that show how to form the complex conjugate of the above function (i don't see the complex parts).
What's the problem with the Schroedinger equation? Are you using the time-independent version (I assume you should be), is there a potential energy associated with this wavefunction?
Further, the complex conjugate of a real valued function is just the real function again. So normalization should look something like:
1=A2 [itex]\int[/itex]sinh2(x)dx
This is my solution to the normalization of the wave equation. I am sorry I am totally new at this.
[PLAIN]https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/249293_246586558696823_100000364410765_866703_7618168_n.jpg
Is it correct? I just followed wikipedia's
http://en.wikipedia.org/wiki/Normalizable_wave_function#Example_of_normalization
My question on the Schroedinger Eq. is that: Should i use the exponential form of the hyperbolic function? or does it matter if i use the hyperbolic? In the normalization above i used the exponential form.
When you use the wavefunction in the Schrödinger equation, it shouldn't matter what form (hyperbolic or exponential) you use. Your normalization is off however. The integral of sinh2(x) is:
Exponential form: [itex]\frac{1}{4}[/itex] (exp(2x)/2+exp(-2x)/2-2x)
Hyperbolic form: [itex]\frac{1}{4}[/itex] (sinh(2x) -2x)
Further, you need to take the integral only between o and L, the other parts can be ignored. I may be reading this wrong, but it seems like you tried to absorb the exponentials into A2 and ignored any actual integration.
Cheers,
-Malus
thanks! I did the integration. and found what the factor is. thanks also for pointing that hyperbolic or exponentials can be used!.
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 21 ·
