How Do You Solve Complex Pendulum Problems Involving Tension and Angles?
  • Thread starter Thread starter skivail
    Pendulum Weight
The discussion revolves around complex pendulum problems involving tension and angles, specifically focusing on the dynamics of a pendulum bob attached to a massless string. The original poster presents two questions regarding the angle of release for specific tension conditions in the string.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between tension, gravitational force, and the motion of the pendulum. They discuss using Newton's second law, centripetal force, and conservation of energy to analyze the problems. There are attempts to derive angles using trigonometric relationships and energy considerations.
Some participants have provided detailed mathematical reasoning and equations related to the problems. There is an ongoing request for further clarification and verification of calculations, particularly for the second question. Multiple approaches are being discussed, but no consensus has been reached on the final answers.
Participants are working under the constraints of homework guidelines, which may limit the extent of assistance provided. The original poster's request for detailed explanations suggests a desire for deeper understanding rather than just solutions.
skivail
Can anybody do these problems, and if you can, show and explain to me exactly how you did them?
The problems involve a pendulum bob of mass m that’s attached to a massless string of length l.
1. At what angle from the vertical should the bob be released so that the tension in the string at the bottom of the swing would be 1.8 times the pendulum’s weight?
2. Now, with the bob in #1 having swung through the vertical position, at what angle beyond the vertical does the string tension become exactly equal to the bob’s weight?
At the bottom,
[tex]T-mg=\frac{mv^2}{l}[/tex]
T=1.8 mg; then
[tex]v^2=0.8gl[/tex]
v is the speed of the pendulum at the bottom.
Law of conservation of energy :
[tex]mgh=\frac{1}{2}v^2[/tex]
h is the height of the pendulum relative to the bottom before it is released.
h=0.4l
Trig formula :
[tex]cos\theta=\frac{l-0.4l}{l}[/tex]
[tex]\theta=53.1^0[/tex]
For question #2, use
1. Newton's 2nd law and the centripedal force formula.
2. Use the law of conservation of energy.
Similar to question #1.
Thanks.
Is there anyway that you could work out part 2 so i could check my work?
Centripedal force & Newton's 2nd Law & Law of conservation of energy
At that position :
[tex]T-mgcos\alpha=\frac{mv^2}{l}[/tex]
[tex]mg(1-cos\alpha)=\frac{mv^2}{l}[/tex]...(1)
v is the speed of the pendulum at that position.
Pendulum's initial energy = Pendulum's energy at that position
[tex]mgh=\frac{1}{2}mv^2+mgH[/tex]
H is the height of the pendulum relative to the bottom at that position.
h is the initial height of the pendulum calculated in question #1.
[tex]H=l-lcos\alpha[/tex]
[tex]=l(1-cos\alpha)[/tex]
Then
[tex]0.4gl=\frac{1}{2}v^2+gl(1-cos\alpha)[/tex]
[tex]v^2=0.8gl-2gl(1-cos\alpha)[/tex]...(2)
(2) into (1) :
[tex]g(1-cos\alpha)=\frac{0.8gl-2gl(1-cos\alpha)}{l}[/tex]
[tex]1-cos\alpha=0.8-2+2cos\alpha[/tex]
[tex]\alpha=42.8^0[/tex]
  • · Replies 21 ·
  • · Replies 26 ·
