Identify Element X: Wavelength, Valence Shell, and Quantum Numbers
  • Thread starter Thread starter chjopl
    Element
The discussion focuses on identifying element X based on its wavelength, valence shell, and quantum numbers. The wavelength of radio waves from a 97.1 MHz FM station is 30 million times greater than the energy difference between the excited and ground states of hydrogen, calculated to be 1.0287 E -7 m. The principal quantum number M for element X's valence shell is linked to the energy of an electron falling from shell M to the excited state. Additionally, the number of unpaired electrons in element X correlates with the quantum designations n=2, ml=-1, m=-1/2, suggesting a relationship with transition metals like manganese (Mn).
  • Understanding of quantum mechanics and quantum numbers
  • Familiarity with the hydrogen atom's energy levels
  • Knowledge of Planck's constant and energy calculations
  • Basic concepts of atomic structure and electron configurations
  • Research the energy levels of hydrogen and their corresponding wavelengths
  • Study the properties of transition metals, particularly manganese (Mn)
  • Explore the significance of angular quantum numbers in atomic structure
  • Learn about the formation of stable ions for elements beyond atomic number 120
Chemistry students, physicists, and educators seeking to deepen their understanding of quantum mechanics, atomic structure, and the identification of elements based on quantum properties.
chjopl
From the information below identify element x:
A. The wavelength of the radio waves sent by an FM station brodcasting at 97.1 MHz is 30 million times greater than the wavelength corresponding to the energy difference between a particular excited state of the hydrogen atom and the ground state.
B. Let "M" represent the principal number for the valence shell of element x. If an electron in the hydrogen atom falls from the shell "M" to the inner shell corresponding to the excited state mentioned above in part A, the wavelength of light emiited is the same as the wavelength of an electron moving at the speed of 570m/s
C. The number of unpaired electrons for element X in the ground state is the same as the maximum number of electons in an atom that can have the quantum number designations: n=2, ml=-1, m=-1/2
D. Let A equal the charge of the stable ion that would form when the undiscovered element 120 forms ionic compounds. This value of A also represents the angular (or azimuthal) quantum number for the subshell containing the unpaired electron(s) for element X.
Please help me with this...all this did was confuse me
Chemistry news on Phys.org
For this part, I get that the wavelength is 1.0287 E -7 m for the energy difference between the excited state of hydrogen and the ground state. Convert this number into energy using Planck's constant.
One part is bolded because it's important.
Here you are told to add the energy of an electron at 570m/s to the energy of the excited state found in part A. Energy from part A + energy from part B = energy at level M. If you have a table of hydrogen energy levels, you can easily find the value for M.
Can't basically any atom with a 2px electron have these numbers? Maybe it just refers to Boron which has 5 electrons. 5 unpaired electrons would mean the atom is in the same column as Mn. The atom is either Mn, Tc, Re, or Bh.
D. Let A equal the chare of the stable ion that would form when the undiscovered element 120 forms ionic compounds. This value of A also represents the angular (or azimuthal) quantum number for the subshell containing the unpaired electron(s) for element X.
I have no idea what this means.
I am still having trouble figuring out B and D...anyone able to help??
11K
  • · Replies 16 ·
16K
