Integrating Using Trigonometric Substitution
The discussion revolves around evaluating the integral \(\int\frac{x^{2}}{\sqrt{4-9x^{2}}}\) using trigonometric substitution, a technique commonly applied in calculus to simplify integrals involving square roots of quadratic expressions.
  • Participants discuss various substitutions for the integral, with some suggesting \(4\sin\vartheta = \sqrt{4-9x^{2}}\) and others proposing \(x = \frac{2}{3}\cos\vartheta\). There are questions about the appropriateness of these substitutions and the relationship between the sides of the triangle formed by the expression.
The conversation includes attempts to clarify the setup of the problem and the trigonometric relationships involved. Some participants express confusion about the choice of triangle legs and the implications of different substitutions. There is acknowledgment of errors in reasoning, but no consensus has been reached on the best approach.
Participants note the importance of correctly identifying the hypotenuse and the legs of the triangle in relation to the integral's expression. There is also mention of the need to differentiate correctly when applying substitutions.
prosteve037
Use the method of trigonometric substitution to evaluate the following:
[itex]\int\frac{x^{2}}{\sqrt{4-9x^{2}}}[/itex]
The only relevant equation that I could think of for this one was the trig identity:
[itex]sin^{2}\vartheta + cos^{2}\vartheta = 1[/itex]
This is what I got from trying this problem:
[itex]\sqrt{4-9x^{2}}[/itex] is a difference between two squares, so it's a leg of a right triangle. So I let [itex]4sin\vartheta = \sqrt{4-9x^{2}}[/itex] to satisfy the definition of sine (Opposite Side over Hypotenuse).
Then, I let [itex]x^{2} = \frac{4}{9}cos\vartheta[/itex] to satisfy the definition of cosine.
Differentiating this same function with respect to [itex]x[/itex], I got:
[itex]\frac{\frac{-2}{9}sin\vartheta}{\sqrt{\frac{4}{9}cos\vartheta}}[/itex]
Substituting these into the original function:
[itex]\int{\frac{\frac{4}{9}cos\vartheta}{4sin\vartheta} \times \frac{\frac{-2}{9}sin\vartheta}{\sqrt{\frac{4}{9}cos\vartheta}}d\vartheta}[/itex]
[itex]\int{\frac{\frac{4}{9}cos\vartheta}{4sin\vartheta} \times \frac{\frac{-2}{9}sin\vartheta}{\frac{2}{3}\sqrt{cos\vartheta}}d\vartheta}[/itex]
[itex]\int{\frac{1}{9} \times \frac{cos\vartheta}{sin\vartheta} \times \frac{-1}{3} \times \frac{sin\vartheta}{\sqrt{cos\vartheta}}d\vartheta}[/itex]
[itex]\frac{-1}{27}\int{\frac{cos\vartheta}{\sqrt{cos\vartheta}}d\vartheta}[/itex]
At this point, I got stuck and didn't know what to do. I tried using a modified version of the identity above and just went on to see if I could get anywhere but failed.
Thanks
they hypotenuse is actually 2, remember c^2=a^2 + b^2, the other leg is actually 3x
I can't really see how you got these substitutions... A standard substitution for this problem would be [itex]x = \frac{2}{3}\cos\vartheta[/itex]
It may help you to indicate that x is the variable of integration, by including dx in your integral: [itex]\displaystyle \int\frac{x^{2}}{\sqrt{4-9x^{2}}}\,dx\,.[/itex]
To elaborate on GreenPrint's post:
If [itex]\sqrt{4-9x^{2}}[/itex] is a leg of a right triangle, then the hypotenuse would likely be 2 and the other leg 3x.
As you say, sine is opposite over hypotenuse, so either [itex]\displaystyle \sin(\theta)=\frac{3x}{2}[/itex] or [itex]\displaystyle \sin(\theta)=\frac{\sqrt{4-9x^{2}}}{2}\,.[/itex]
cos(θ) is the other.
Just making info easier to understand.
[PLAIN]http://img856.imageshack.us/img856/4011/derpto.png
Make sure you find dx to get dθ.
No, you must have [itex]x= (2/9)cos(\vartheta)[/tex].<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Differentiating this same function with respect to [itex]x[/itex], I got:<br /> <br /> <span style="font-size: 12px">[itex]\frac{\frac{-2}{9}sin\vartheta}{\sqrt{\frac{4}{9}cos\vartheta}}[/itex]<br /> <br /> <br /> Substituting these into the original function:<br /> <br /> <span style="font-size: 12px">[itex]\int{\frac{\frac{4}{9}cos\vartheta}{4sin\vartheta} \times \frac{\frac{-2}{9}sin\vartheta}{\sqrt{\frac{4}{9}cos\vartheta}}d\vartheta}[/itex]<br /> <br /> <span style="font-size: 12px">[itex]\int{\frac{\frac{4}{9}cos\vartheta}{4sin\vartheta} \times \frac{\frac{-2}{9}sin\vartheta}{\frac{2}{3}\sqrt{cos\vartheta}}d\vartheta}[/itex]<br /> <br /> <span style="font-size: 12px">[itex]\int{\frac{1}{9} \times \frac{cos\vartheta}{sin\vartheta} \times \frac{-1}{3} \times \frac{sin\vartheta}{\sqrt{cos\vartheta}}d\vartheta}[/itex]<br /> <br /> <span style="font-size: 12px">[itex]\frac{-1}{27}\int{\frac{cos\vartheta}{\sqrt{cos\vartheta}}d\vartheta}[/itex]<br /> <br /> At this point, I got stuck and didn't know what to do. I tried using a modified version of the identity above and just went on to see if I could get anywhere but failed.<br /> <br /> Thanks</span></span></span></span></span> </div> </div> </blockquote>[/itex]
Oh wow. Okay. Yeah I know what I did wrong now. Thanks everyone!
I'm still a little confused about choosing which leg to be the radical though. Does it matter? I was taught to just put the radical term on the opposite side of the reference angle. But are there instances in which this won't work?
just think about it
c^2 = a^+b^2
in order to get something in the form sqrt(z^2 - y^2)
z can only equal one thing, the hypotenuse and y can be any leg
No, it doesn't matter.
  • · Replies 105 ·
13K
