Confusing definition of resolvent set
The resolvent set definition for a bounded linear operator T on a Banach space X states that λ ∈ ρ(T) if and only if (T - λ) is bijective with a bounded inverse. This definition aligns with the inverse mapping theorem, which confirms that (T - λ) being both injective and surjective implies the existence of a bounded inverse. However, the professor's definition includes the condition that the range of (T - λ) equals X, which adds clarity regarding the operator's domain, particularly when discussing unbounded operators that may only be densely defined.
  • Understanding of bounded linear operators
  • Knowledge of Banach spaces
  • Familiarity with the inverse mapping theorem
  • Concept of operator ranges and domains
  • Study the properties of unbounded operators in functional analysis
  • Learn about the implications of operator density in Banach spaces
  • Explore the inverse mapping theorem in greater detail
  • Research the differences between injective and surjective operators
Mathematicians, functional analysts, and students studying operator theory, particularly those focusing on the properties and definitions of resolvent sets in the context of bounded and unbounded operators.
AxiomOfChoice
The definition I have found in a couple of places is the following: We have [itex]\lambda \in \rho(T)[/itex] for a bounded linear operator [itex]T[/itex] on a Banach space [itex]X[/itex] iff [itex](T-\lambda)[/itex] is bijective with a bounded inverse. (This seems to be equivalent to just saying that [itex](T-\lambda)[/itex] is both injective and surjective, since this implies [itex](T-\lambda)^{-1}[/itex] is bounded by the inverse mapping theorem.) But in class, my professor said that [itex]\lambda \in \rho(T)[/itex] iff [itex](T-\lambda)^{-1}[/itex] exists and [itex]\mathcal R(T-\lambda) = X[/itex].
I don't see why my professor's definition doesn't contain superfluous information. Obviously, if [itex]\mathcal R(T-\lambda) = X[/itex], then [itex](T-\lambda)[/itex] is surjective. But doesn't saying "[itex](T-\lambda)^{-1}[/itex] exists" contain the surjectivity statement? I mean, why not just say: "We need (1) [itex](T-\lambda)[/itex] injective and (2) [itex](T-\lambda)[/itex] surjective" and be done with it? It just seems he's said more than he really needs to.
Of course, if [itex]\mathcal R(T-\lambda) \neq X[/itex], I guess that [itex](T-\lambda)^{-1}[/itex] only makes sense as a map [itex]\mathcal R(T-\lambda) \to X[/itex]...so you can't really just say "[itex]\lambda \in \rho(T)[/itex] iff [itex](T-\lambda)^{-1}[/itex] exists as a bounded operator" without there being some ambiguity...because can't [itex](T-\lambda)^{-1}: \mathcal R(T-\lambda) \to X[/itex] be bounded without having [itex]\mathcal R(T-\lambda) = X[/itex]?
You are absolutely correct, when dealing with the classical functional analysis.
However, your professor most likely likes to work with unbounded operators. With unbounded operators, it's normal to have operators that are only densely defined (that is: only defined on a dense subset). So it's ok if the inverse of an operator is only defined on a dense subset. What your professor asks is that the operator is actually defined on the entire set, and not only on the dense subset.
  • · Replies 0 ·
