Thread Closed
Event horizon and singularity
Share Thread Thread Tools
Nov9-04, 01:04 PM   #1
Recognitions:
Consider a Schwarzschild spacetime. If the singularity due to the point mass is removed (e.g. with an homogeneous matter distribution), does the event horizon disappear? If yes (I assume this is the case), how can be proven that there exists no event horizon if there is no singularity? May be it is enough to show that in the metric for the interior of stars (with homogeneous mass distribution) there is no change of the timelike coordinate from t to r at any r, as in case of the vacuum Schwarzschild solution for r = 2GM (Schutz p. 290)? I was not able to find an expression for the metric of the interior of stars to check this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov9-04, 02:21 PM   #2
Recognitions:
Retired Staff Staff Emeritus
There's an analysis of the metric of a star with a constant density rho online
here
It's very detailed and long, being a chapter from a textbook, you'll probably have to print out & study it to get very far.
The same results are also in MTW's gravitation. This topic came up late in the thread "The Mass of a Body" that you'll find here on Physics Forum, though I'm not sure if there will be anything useful in that discussion for your question.
I think another poster, DW, once posted some formulas about static stars as well, you might try searching the physics forum for that, too.
As far as the event horizon goes, I think the best test is to consider whether or not light can escape from an object. If there are null geodesics that connect the interior of the star to the exterior, it doesn't have an event horizon. [I haven't double-checked this definition though.]
[add]
I should clarify, there should always be ingoing null geodesics, but if there is a horizon, there won't be outgoing ones.
Nov10-04, 05:29 AM   #3
Recognitions:
Thanks, pervect, I will take a look. Your proposal to consider the outgoing geodesics to prove whether an event horizon exists or not seams to be the best one, but I can imagine it may be difficult to do the calculations. What do you think about this possibility:
Quote by hellfire
Thread Closed
Thread Tools
Similar Threads for: Event horizon and singularity
Thread Forum Replies
How does a photon's event horizon look like? Special & General Relativity 6
Event Horizon Special & General Relativity 9
Event Horizon Special & General Relativity 1
Event Horizon = Singularity? Special & General Relativity 1
The Unexistence of Singularity Inside the Event Horizon Special & General Relativity 13
