Convergence of a Series with the Ratio Test
  • Thread starter Thread starter Alem2000
    Series
The discussion revolves around the convergence of a series using the ratio test, specifically the series \(\sum_{n=3}^{\infty}\frac{x^n}{n3^n}\). Participants are tasked with determining the values of \(x\) for which the ratio test is conclusive regarding convergence or divergence, and to explore cases where the test is inconclusive.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the ratio test, calculating the limit of the ratio of consecutive terms. There are attempts to simplify the expression and identify conditions for convergence and divergence based on the limit obtained.
Some participants have successfully derived the limit and identified the conditions under which the series converges or diverges. There is ongoing exploration of specific cases where the ratio test is inconclusive, with suggestions to apply other convergence tests for those scenarios.
Participants mention specific values of \(x\) (3 and -3) that require further examination due to the nature of the series at those points. The discussion includes references to the harmonic series and the Leibniz test for alternating series.
Alem2000
Sorry about the title everyone but I've posted numerous threads on series and I had to choose an apropriate title :-p
The problem asks to use the ratio test, and determine for which values of x the test is conclusive-either converging or diverging. Then check those cases where the test is inconclusive by some other means.
here is the the series [tex]\sum_{n=3}^{\infty}\frac{x^n}{n3^n}[/tex]...converge or diverge here is what i did [tex]\frac{a_{n+1}}{a_n}[/tex] and that came out to be [tex]\frac{x^{n+1}}{(n+1)(3^{n+1})}[/tex] multiplie by the [tex]\frac{n3^{n}}{x^{n}}[/tex] and after you cross out similar variables and it comes out to be
[tex]\lim_{x\rightarrow \infty}\frac{xn}{3(n+1)}[/tex]
[tex]\frac{a_{n+1}}{a_n}=\frac{x^{n+1}n3^n}{x^n(n+1)3^{n+1}}=\frac{nx}{(n+1)3}[/tex]
thanks galileo but I got that far just had problems latexing it
So you get
[tex]\lim_{n \to \infty} \left| \frac{n}{(n+1)}\frac{x}{3}\right| = \frac{|x|}{3}[/tex]
And you know this is stricly less than 1 for it to be conclusively converging, strictly greater than 1 to be conclusively diverging, and inconclusive at 1. So you must test the values for which the expression equals one.
--J
The remaining cases are x=3 and x=-3
If x=3 then the series reduces to the harmonic series, which diverges.
If x=-3 then we have an alternating series, and we can use the Leibnitz test (whose exact conditions escape me right now).
  • · Replies 21 ·
