Calculating Final Velocity: 1.5kg Cart with 85g Balls vs 255g Ball at 3.5 m/s"
  • Thread starter Thread starter dishoom
    Momentum
The discussion focuses on calculating the final velocity of a 1.5 kg cart propelled by either three 85g balls or one 255g ball, both ejected at a speed of 3.5 m/s relative to the cart. The momentum conservation principle is applied, where the initial momentum of the system equals the final momentum after the balls are ejected. The calculations reveal that the cart's final velocity after ejecting three 85g balls is greater than that after ejecting a single 255g ball, confirming the expected outcome based on mass and velocity relationships.
  • Understanding of momentum conservation principles
  • Basic knowledge of physics equations related to mass and velocity
  • Familiarity with relative velocity concepts
  • Ability to perform algebraic calculations
  • Study the conservation of momentum in multi-body systems
  • Learn about relative velocity in physics
  • Explore examples of momentum calculations involving varying masses
  • Investigate the effects of friction on momentum calculations
Physics students, educators, and anyone interested in understanding momentum dynamics in mechanical systems.
dishoom
Momentum Poblem.. Need help!
A 1.5 kg cart is propelled forward by a series of 85g balls being ejected from the rear of the cart with a speed of 3.5 m/s relative to the cart. Calculate the speed of the cart after three balls have been ejected. Compare this to the speed of the cart if it had ejected a signle 255g ball at 3.5 m/s relative to the cart. Assume negligible friction, calculate the final velocity for each cart?
i have got an answer but the relationship is wrong the first cart should have the faster velocity... anyone help i need to understand this!
mv=mv
First Ball:
1.415kg(v)=(0.085kg)(3.5m/s)
solve for v then just do the same for second+third
mv=mv
1.245kg(v)=(0.255kg)(3.5m/s)
solve for v
umm... that's not it... it's suppose to be relative to the cart.. i know this cause i did something similar to urs and i got it wrong..
and by the way the mass of balls are separate...
  • · Replies 24 ·
  • · Replies 19 ·
