marcus said:
Is there some logical connection between DM and DE? or, since i guess there is, could you sketch out the connection please?
Most cosmology models start with the assumption that Bayronic matter plus dark matter plus dark energy equals the total sum of all stuff in the universe. The amount of dark energy as a proportion of that in turn drives what the cosmological constant must be. Ditch the DM and you do a number of things.
1. You may change the amount of dark energy needed to make the cosmological constant and the toal amount of mass-energy in the universe balance. This impacts, for example the matter-energy density of space which shows up in the p terms in Friedman's equations.
2. You throw off a whole bunch of assumptions that form the basis for determining basic cosmological constants. For example, one important set of assumptions flows from the assumption that CBM background radiation profiles are a product of cold dark matter. If you have a different model that produces the same CBM background radiation profile without cold dark matter, you fundamentally change the assumption used to place limits on permissible values like the cosmological constant (to which the dark energy fraction is sensitive) and the density of space. The chart on page 2 of this paper: http://arxiv.org/PS_cache/astro-ph/pdf/0403/0403064.pdf shows in full color how the cosmological constant and fraction of matter made of matter (Omega M) are related and shows quite vividly that the orange splotch which represents the permissible range based on CBM data is the biggest straight jacket on that result. Going from CDM to MOND both changes the shape of that straight jacket (this point 2) and pushes you to a different point on the Omega M axis (point 1 above).
3. CDM basically says "Newtonian gravity applies", we have these "dynamics" and we see this "mass", where do I need to put more mass to make the number fit. Locally, these results should be the same. But, when you leave the localized system of say, a galaxy, the gravity from the CDM to make that localized system fit is going to fall off as /1R^2. But, in a MOND regime, you are giong to see that gravity outside the localized system fall off as 1/R.
Consider this ill thought out, spur of the moment example. Suppose gravity has a very low force which induces an accelleration a its fringe with radius 1 unit. A hundred galactic radii out CDM says gravity is 0.0001a while MOND says that gravity is 0.01a. The effect is small, but it is non-zero. We know that in GR, gravity induces time dilation. If gravity in the middle of nowhere is 100-1000 times what was previously anticipated, this could produce a small effect, but one that would be measurable, over long distances. If that happened, it would intensify redshifts without breaking the harmony between redshifts and time dilation which we now observe. Screw up redshifts and you screw up Hubble's constant, driving it down. Drive Hubble's constant down 30%, and you don't need dark energy any more. Moreover, maybe with points 1 and 2 above considered, maybe now you only need to drive down Hubble's constant by 15% to make DE go away.
Obviously, if I had it all worked out, I'd write a paper and publish it, but the gist of the notion is that CDM assumptions are deeply relied upon for a foundation of our current cosmological estimates and constant calculations.
this article you cite is about physical evidence for DE.
This is just to point out that as nice as it would be to get rid of DE, that if you replicate studies like that one where DE is shown to be "real" then no matter how good a theory you can come up with to eliminate DE, that theory will be wrong. Of course, maybe physical evidence of DE is really just physical evidence for something else (like distorted gravity) that looks like DE.
the Bekenstein article you flagged for us earlier is, if I understand correctly, about a nice MOND model that does away for the need for DM.
If we do away with the need for DM to explain galaxy rotation curves and to explain how clusters of galaxies hang together, then we still have the accelerating expansion of the universe-----and its apparent (near) flatness.
So it seems we would still need a positive cosmological constant, which I picture as a slight built-in curvature that the universe just has without the need for matter to cause it----or some corresponding amount of dark energy---to balance the books.
does Bekenstein obviate DE too? sorry if I am not getting it.
just to keep the links handy, there was this paper in October about possible ways to avoid the need for Dark Energy----with some majorleague co-authors:
Sean M. Carroll, Antonio De Felice, Vikram Duvvuri, Damien A. Easson, Mark Trodden, Michael S. Turner
The Cosmology of Generalized Modified Gravity Models
27 pages, 7 figures
http://arxiv.org/abs/astro-ph/0410031
"We consider general curvature-invariant modifications of the Einstein-Hilbert action that become important only in regions of extremely low space-time curvature. We investigate the far future evolution of the universe in such models, examining the possibilities for cosmic acceleration and other ultimate destinies. The models generically possesses de Sitter space as an unstable solution and exhibit an interesting set of attractor solutions which, in some cases, provide alternatives to dark energy models."
Bekenstein actually puts a cosmological constant at the canonical value in his model. But, Bekenstein isn't a cosmologist, he's a phenomenolical astronomer and isn't a natural at thinking through the subtler implications of his own theory. I was alluding to Carroll's article and similar articles (I believe Caroll actually mentions relativistic version of Milgrom's theory), to suggest that there may be subtle effects inducing curvature in a Caroll like analysis that flows from a Bekenstein theory which Bekenstein didn't catch but which would eliminate the need for DE.
can't comment, at least for now. but my feeling is that we might be seeing the germs of some kind of simplification which can dispense with either DM or DE, or both. Might involve a new physical constant.
Yup. I think that it is quite likely that some combination of factors are going to return us to a no DM, no DE understanding of the world, which FWIW, also takes lots of pressure of the accellerator guys to discover new stable particles that can fit the bill of DM, and finely tuned non-zero vacuum energy to explain DE. Non-Bayronic means you have to come up with yucky stuff like Gondolo describes in this article: http://arxiv.org/PS_cache/astro-ph/pdf/0403/0403064.pdf (WIMPZILLAs et al), and I'm not sure CDM people have really come to terms with just how radical a proposal that would be.
