Is it possible to create an earthquake model
  • Thread starter Thread starter Sherenon
    Earthquake Model
The discussion revolves around the feasibility of creating an earthquake model, particularly focusing on the generation of P-S-L waves associated with tectonic plate interactions. Participants explore both theoretical and practical aspects of simulating seismic waves, including methods to reduce pressure between tectonic plates and the challenges of replicating these phenomena in a controlled environment.
  • Homework-related
  • One participant proposes a project hypothesis related to reducing the magnitude of P-S-L waves generated by tectonic plate collisions.
  • Another participant mentions that while theoretically it is possible to reduce pressure between plates, practical methods for injecting solutions and the conditions required remain uncertain.
  • Some participants note that creating actual earthquake waves in a laboratory setting is impractical, but suggest that the effects of such waves on the Earth's surface can be simulated.
  • One participant references field experiments where pumping liquid into fault zones has been shown to increase smaller seismic events, raising concerns about potentially triggering larger earthquakes.
  • Experiments conducted by institutions like the USGS are mentioned, where materials are stressed to simulate P and S waves, although creating lower frequency Love and Raleigh waves may be more challenging.
  • Participants express a need for research papers or detailed information to support their projects, with one participant recalling past experiments they observed.
Participants generally agree that while theoretical models exist, practical implementation and the risks involved in simulating earthquakes remain contentious and unresolved. Multiple competing views on methods and implications are present throughout the discussion.
Participants acknowledge limitations in their understanding of the methods and conditions necessary for effectively simulating seismic waves, as well as the potential risks associated with manipulating fault zones.
Sherenon
Well i am researching on seismology and tectonic plates. My project hypothesis is related to reducing the magnitude of P-S-L waves that are generated when tectonic plates collide,create subduction zones etc.
for the project i have a choice of submitting a theoretical or real model.my query is that ... is it possible to generate spl waves in a controlled model as they are generated in real.
Hi Sherenon, so have you found anything for your project and how is it going on?
theoretically its proved that we can reduce the pressure between plates,the real problem is the method by which we inject the aqueous solution and the conditions in which it may be possible to actually reduce the pressure of the plates in the real world.However since its a high-school project we will mostly stick to the theories and model.
As for the Earth quake model creating these waves in a room is out of the question.but i can stimulate the effects they would have on the surface of the Earth by some methods. we will post the project abstract soon and keep u updated on progress
actually its a little more than theory :) it has been played with in the field. pumping liquid into faults/fault zones has been proven to increase the number of smaller events thus summising that pumping enough liquid in over a period of time would produce enough smaller events to decrease the risk of a larger event.
The real worry/problem is... pumping fluid into a large fault such as the San Andreas fault in California, that you may well trigger the huge event that was not far from occurring anyway on that section of the fault.
A mining/drilling term call "fracking", rock fracturing by the pumping in of fluids to release hydrocarbons etc from many small pockets into a single larger reservoir (sp?) is often accompanied by many many small quakes. this has bee occurring recently a bit nth of Little Rock, AR, USA.
I have seen experiments done by the USGS and assoc institutions using large sheets of materials pressed together then stressed till they slid along their contact plane. The resulting vibrations recorded on geophones well resembled the P and S waves of an actual quake. The lower freq Love and Raleigh waves assoc with large, near surface quakes may be a bit more difficult to create in the lab. I may have been done, I'm personally not aware of it.
Dave
Dave
Are there any research papers or more detailed information about this process on the internet or anywhere else which can be used as reference for my project..
thankyou
thankyou
I don't know, quite possibly. you will have to do some searching. Note the first 5 words in my previous post... "I have seen experiments done ..."
I actually watched the experiments some 15 - 20 years ago.
cheers
Dave
hmmm in my email, I got a post from the forum, by a poster ... Avena... but their post isn't showing in the forum thread. Maybe a good thing is was a little rude and demanding ;)
I wonder if it was removed by the mod's ?
Dave
  • · Replies 26 ·
  • · Replies 65 ·
29K
