What is Duty Cycle and How Does it Affect Motors?
  • Context: High School
  • Thread starter Thread starter PainterGuy
    Cycle Example Motor
The discussion revolves around the concept of duty cycle, particularly in relation to motors. Participants explore definitions, applications, and implications of duty cycle in various contexts, including mechanical and electrical systems.
  • One participant provides two definitions of duty cycle, emphasizing its operational limits and percentage of active time.
  • Another participant clarifies that the motor example indicates a duty cycle of 1% based on its operation over a minute, using an automobile starter motor as an illustration.
  • Concerns are raised about the counterintuitive nature of the motor running for only one second, questioning the implications of power ratings and energy consumption over time.
  • A participant corrects the misunderstanding regarding power and energy, noting that watts measure power, not energy, and suggests discussing watt-seconds instead.
Participants express differing views on the interpretation of duty cycle and its implications for motor operation. There is no consensus on the understanding of how duty cycle relates to energy consumption and power ratings.
Participants highlight the need for clarity regarding definitions and measurements, particularly the distinction between power and energy, which remains unresolved.
PainterGuy
Hi
I found these two definitions of duty cycle:
1: The duty cycle of a machine refers to how long it can keep operating before it needs a rest, or what percentage of the time it's designed to be in use. For instance, a machine gun might only be able to fire continuously for 100 rounds before it needs to be allowed to cool.
For some machines, you could wear out the mechanism well before it came to the end of the warranty period if you left it printing continuously.
For example, a printer that is capable of printing 30 copies per minute would probably wear out in weeks if it was always printing. Therefore the manufacturer quotes a duty cycle such as "10,000 copies per month".
2: In engineering the duty cycle of a machine or system is the time that it spends in an active state as a fraction of the total time under consideration.
A motor runs for one out of 100 seconds, or 1/100 of the time, and therefore its duty cycle is 1/100, or 1 percent.
What is 'exact' definition of duty cycle in your opinion? Please keep it simple so I can understand it.
I didn't understand at all that motor example. Isn't motor running all the time? Is the example speaking of DC motor or AC?
Thank you for the help.
Regards
The motor example states that the motor only runs for one second when watched for one continuous minute. So the duty cycle is 1%. A good example of this scenario would be with an automobile starter motor. It runs for a second and then doesn't run for a while. However, to convey a real "duty cycle" value I think it should be watched through several cycles. Otherwise one might watch a car starter motor for only the one second it was running and conclude its duty cycle is "normally" 100%--yet we know a typical starter motor would last long at that duty cycle!
"Duty cycle" can apply to devices with any repetition rate, from something that runs a portion of the year to an electronic device that cycles billions of times a second. Heat dissipation (and resulting damage) is typically the issue but there may be other reasons one needs to limit the "on time" of a device. For example, efficiency may go down while a devices is "on", so you might not want to it run too long at a stretch.
Many thanks, fleem.
But that's what troubles me. To me, it's counterintuitive to even imagine that motor runs for 1 second. If the motor is rated 50W, then in 60 seconds wouldn't it consume 3000W rather than only 50W? If you agree with me that it will take in 3000W then what's the reason for saying that it only runs for 1 second? Please help me. Thanks
Cheers
PainterGuy said:
Many thanks, fleem.
Cheers
'Watts' is a measure of power (energy per time), not energy. Perhaps you want to talk about watt-seconds?
Sorry. I wanted to say:
that it will take in 3000 Joules
instead.
Cheers
  • · Replies 27 ·
  • · Replies 31 ·
9K
  • · Replies 169 ·
17K
  • · Replies 87 ·
11K
  • · Replies 22 ·
