Oblique Collision Trigonometry problem
The discussion revolves around a problem involving an oblique collision between two smooth spheres, focusing on the angles of motion before and after the impact, as well as the coefficient of restitution. Participants are tasked with demonstrating a relationship between the tangent of these angles.
  • Mixed
  • Participants explore the application of the coefficient of restitution and conservation of momentum in the context of the collision. There are attempts to express the relationship between the angles A and B using trigonometric identities. Some participants question the assumptions regarding the direction of motion of the second sphere and the treatment of velocity components.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided guidance on manipulating equations and understanding the implications of the coefficient of restitution. There is a recognition of potential errors in earlier attempts, leading to further exploration of the relationships between the variables involved.
Participants note that the problem is set under ideal conditions, and there is an emphasis on the assumptions made regarding the motion of the spheres and the application of trigonometric relationships. The discussion reflects a mix of high school-level physics concepts and the nuances of collision dynamics.
Darth Frodo
A smooth sphere collides with an equal sphere which is at rest. Before the impact the line of motion of the first sphere makes an angle A with their line of centers, after the impact this is angle B. The coefficient of restitution is 1/4. Show that 8TanA = 3TanB
-e = (V1 - V2) / (U1 - U2)
M1U1 + M2U2 = M1V1 + M2V2
Initial Velocity 1: (XcosA i + XsinA j)
Initial Velocity 2: (0i + 0j)
Final Velocity 1: (YcosB i + YsinB j)
Final Velocity 2: (P i + 0 j) XsinA = YsinB. J components are equal.
Coefficient of restitution
-1/4 = [YcosB - p] / [XsinA]
-XsinA = 4YcosB - 4pConservation of momentum in i direction
masses are equal.
U1 + U2 = V1 + V2
XcosA = YcosB + p
XcosA - YcosB = p-XsinA = 4YcosB - 4( XcosA - YcosB )
-XsinA = 8YcosB - 4XcosA
-XsinA / -XcosA = 8YcosB /-XcosA -4XcosA /-XcosA
Tan A = (8YcosB) / (-XcosA) - 4
This equation holds for one-dimensional motion. In general, the coefficient of restitution is (speed of separation)/(speed of aproach). You need to calculate with the magnitude of relative velocities before and after the collision.
Was it given that the second ball moves in the direction of the line connecting their centres?
ehild
I thought that was the equation for relative velocity? According to my book anyway. It shows the derivation.
As for moving only on the i axis, according to my book "the bounce / impact takes place along the i axis therefore the j component of the velocity remains unchanged. I'm not having a problem with the physics, just the trig. I can't whittle it down to 8Tan A = 3TanB
You took the line connecting the centres of the spheres as x-axis and the y-axis is perpendicular to this line. Nothing ensures that the second ball will move along the x axis.
In case of bounce from the ground or from a wall, the force during impact is normal to the wall, so only the normal component of the velocity changes. It is not the case here.
The coefficient of restitution gives the relation between the magnitudes of the relative velocities, not only of the x components. See:https://www.physicsforums.com/library.php?do=view_item&itemid=270
ehild
"You took the line connecting the centres of the spheres as x-axis and the y-axis is perpendicular to this line. Nothing ensures that the second ball will move along the x axis."
But the j component of the velocity never changes. If it's originally 0 doesn't it stay 0?
This is what my book says. See picture attached.
OK, it is an approximation, which is not always true in reality. Can you kick a ball so as it starts to spin? It is because the interaction between your foot and the ball has tangential component to, not only radial. When friction is negligible between the colliding balls, however, the approximation is valid. And the balls in this problem are perfectly smooth. So you are right, the y components do not change.
As for the coefficient of restitution, I see, there are different definitions in different books.
You made a mistake when writing up the coefficient of restitution:
It has to be X cosA.
And use the equation for the y components of velocity, too: XsinA=YsinB
ehild
Yeah, all the problems I'm doing at the minute are High School and are under "Ideal conditions"
Yes, that mistake messed me up a bit. With that error overcome, I have retried the problem.
Attempt 2
Ball 1 (XcosA i + XsinA j) ----> (YcosB i + YsinB j)
Ball 2 (0i + 0j) ----> (Pi + 0j)
Momentum is conserved in the i direction. Masses are equal.
u1 + u2 = v1 + v2
XcosA = YcosB + P
P = XcosA - YcosB
Coefficient of restitution.
-e = [itex]\frac{v1 - v2}{u1 - u2}[/itex]
[itex]\frac{-1}{4}[/itex] = [itex]\frac{YcosB - P}{XcosA}[/itex]
-XcosA = 4YcosB - 4P
P = [itex]\frac{-XcosA -4YcosB}{-4}[/itex]
So now I have 3 equations.
1. XsinA = YsinB
2. P = XcosA - YcosB
3. P = [itex]\frac{-XcosA - 4YcosB}{-4}[/itex]
From that I get
XcosA - YcosB = [itex]\frac{-XcosA - 4YcosB}{-4}[/itex]
-4XcosA + 4YcosB = -XcosA - 4YcosB
3XcosA = 8YcosB.
And that is as far as I can go.
Darth Frodo said:
3XcosA = 8YcosB.*
And you have the equation for the y components:
XsinA = Y sinB**
Just divide eq. ** with eq * what you get ? You know, do not you, that sinA/cosA=tanA?
ehild
Yeah I understand that Tan A = Sin A / Cos A
But I have never come across dividing one equation with another.
Would you mind explaining please.
It is possible to multiply, divide add or subtract two equations.
If A=B and C=D then A+C=B+D, A-C=B-D, A*C=B*D, and A/C=B/D (here you must be sure that neither C nor D are zero)
Just a primitive example: 2=2, 3=3, dividing the equations you get 2/3=2/3.
Your equations are:
xsinA=ysinB and
3xcosA = 8ycosB
Divide:
[tex]\frac{xsinA}{3xcosA}=\frac{ysinB}{8ycosB}[/tex]
Simplify:
[tex]\frac{sinA}{3cosA}=\frac{sinB}{8cosB}[/tex]
[tex]\frac{tanA}{3}=\frac{tanB}{8}[/tex]
Multiply the whole equation by 24, and you get the solution.
If you do not like to divide equations, you can express sinA from the first equation, cosA from the second one, and find tanA=sinA/cosA.
ehild
Excellent, thank you!
I never realized you could do that.
  • · Replies 16 ·
