Laser/Wave Phenomena Exploration
  • Context: Graduate
  • Thread starter Thread starter Mr. Heretic
    Phenomena
The forum discussion centers on the observation of interference patterns produced by a ~300mW 532nm laser when reflected off a plane mirror at specific angles. The user noted that distinct patterns become visible at approximately 8 degrees and are highly pronounced at around 2 degrees. The discussion also explores potential causes for these patterns, including surface imperfections on the mirror acting as a diffraction grating and partial reflections within the mirror's glass. The user identifies these patterns as resembling Newton's Rings, prompting further inquiry into the underlying physics.
  • Understanding of laser properties, specifically 532nm wavelength lasers.
  • Knowledge of interference patterns and their formation.
  • Familiarity with Newton's Rings and their optical principles.
  • Basic concepts of reflection and refraction in optics.
  • Research the principles of laser interference and diffraction patterns.
  • Study the characteristics and formation of Newton's Rings in detail.
  • Explore the effects of surface imperfections on laser beam behavior.
  • Investigate the physics of partial reflections in optical materials.
Physics enthusiasts, optical engineers, and anyone interested in the practical applications of laser technology and interference phenomena.
Mr. Heretic
Greetings and salutations.
Today I bring with me interesting phenomena, which I managed to reproduce and photograph in detail.
I noticed one when I was enjoying my ~300mW 532nm laser in a dark room, if I reflect the beam off a regular plane mirror with a small angle, it projects 2 separate interference(?) patterns onto an opposing surface, becoming noticeable at about 8 degrees and highly visible at around 2, based on distance measurements and trig.
Both are pictured in the attachments, though I've had to scale and reduce quality woefully to meet the strict filesize guidelines.
I advise downloading the 100% size and quality version for closer inspection from: https://picasaweb.google.com/lh/photo/SLeE64Xo8-6n0dO8JC109p1FDvtn5lS-MCahxU362JM?feat=directlink
Only place I could find to host a 15.3mb image, use the download option on the top left.
Note that the main/large pattern is not centered at the point the beam has reflected to, based on attempts to give the laser only vertical, horizontal and angular shifts: it is affected equally (to the beam point) in the former two, but half as drastically in the angular shifts, which is to say reflected at half the angle.
A second, much smaller pattern can be seen at the actual point of the laser beam, which was only revealed in the photograph, the point is too bright to look at directly so it's possibly an artifact of the camera/lens.
I have two ideas on what could be causing it, but certainly nothing solid:
1. Markings/grit/fingerprints on the mirror surface potentially acting like a diffraction grating, though it's not like any light diffraction I've seen.
2. Partial reflection within the glass of the mirror, creating secondary out-of-phase beams at proximity to the original. (diagram included, attachment 3)
Any ideas?
Science news on Phys.org
Ooh, certainly seems like they are "Newton's Rings", had never heard of them.
Did a bit of reading, but I'm still not sure I understand the exact mechanism that's causing the interference to occur in this instance, then again it's 2:18AM.
I'll interrogate my physics teacher about them tomorrow/today. :]
