Why must vertical acceleration always be negative on projectile motion?
The discussion revolves around the nature of vertical acceleration in projectile motion, particularly focusing on why it is often represented as negative in certain coordinate systems. Participants explore the implications of different coordinate choices and the relationship between velocity, acceleration, and direction.
  • Some participants question why the term -1/2gt^2 is used in the equation for vertical motion, particularly in the context of throwing a ball downward.
  • There is confusion regarding whether negative velocity indicates direction or a decrease in speed, with participants expressing uncertainty about the implications of negative signs in various scenarios.
  • One participant suggests that the signs in equations are dependent on the chosen coordinate system, proposing that different conventions can yield different signs for acceleration and velocity while maintaining the same physical principles.
  • Another participant explains that if "up" is defined as positive, then acceleration due to gravity is negative, while if "up" is defined as negative, the acceleration becomes positive, illustrating the flexibility of coordinate systems.
  • Participants discuss the concept of "slowing down" versus "speeding up," noting that these terms depend on the context of velocity magnitude and direction rather than just the sign of the acceleration or velocity.
Participants generally agree that the choice of coordinate system affects the signs of velocity and acceleration, but there is no consensus on the implications of negative velocity or the best way to interpret these signs in the context of projectile motion.
There is a lack of clarity regarding the assumptions made about coordinate systems and the definitions of velocity and acceleration, which may lead to different interpretations of the same physical situation.
hamsterpower7
[tex]y= y_0 + v_(y0)t - 1/2gt^2[/tex]
why is it -1/2 gt^2?
what if somebody was to throw ball downward?
is that still negative velocity?
wait, does negative in velocity mean direction?? or slowing down
kind of confused while writing this question
if it is direction why is it negative for throwing the ball upward?
is that still negative velocity?wait, does negative in velocity mean direction?? or slowing down
The signs are only due to your choice in coordinates. You can chose different coordinates and make your acceleration positive.The ones you use now are just the least awkward for this situation.Try to flip or rotate your coordinates and get the equations describing parabolic motion. The physics is the same the equations are not.
As bp_psy stated, it is a matter of what your coordinate system convention is.
If you decide "up" is positive, then the acceleration is always negative (since it points down towards what is typically the Earth in these projectile motion problems). If the projectile is moving upwards, the velocity is positive; if it is moving downwards, the velocity is negative. If you decide "up" is negative, the acceleration is always positive because it points down and will have opposite sign. If the projectile is moving up, the velocity is negative; if it is moving downward, the velocity is positive.
The idea of "slowing down" and "speeding up" is kind of vague. The positive/negative sign on the velocity or acceleration doesn't tell you if the object is speeding up or slowing down alone. For example, if you throw a ball upwards, the acceleration points downward and at the beginning you could say it is slowing down. However, after it reaches the top, comes to rest, and begins falling again, you could then say it's speeding up! What "speeding up/slowing down" really refers to is the magnitude of the velocity (in other words, what the velocity is regardless of the sign).
You can use any sign you like but you need to be consistent, once you have made the choice. Slowing down on the way up is the same (-g) as speeding up as you are dropping downwards because the sign for direction is different for up and down.
You just need to let the Maths do the work for you and interpret the answer that comes out of the other end correctly. It can't let you down.
  • · Replies 25 ·
  • · Replies 17 ·
19K
  • · Replies 18 ·
  • · Replies 46 ·
  • · Replies 60 ·
