How do you define the distance between two points in a non-flat 2-D space?
  • Context: Undergrad
  • Thread starter Thread starter gikiian
    Points Space
The discussion revolves around defining the distance between two points in a non-flat 2-D space, exploring both intrinsic and extrinsic approaches to distance measurement. Participants examine concepts such as geodesics, the infimum of curve lengths, and the implications of different metrics on distance calculations.
  • Some participants propose that the distance is defined as the shortest path within the non-flat space, as perceived by beings existing in that space.
  • One participant describes a method for measuring distance by considering all smooth curves between two points and taking the infimum of their lengths.
  • There is a discussion about whether the infimum distance is necessarily realized by a specific curve, with an example provided where no curve achieves the infimum distance in a modified plane.
  • Some participants clarify that a geodesic is a curve with zero acceleration and serves as a generalization of a straight line, but it may not always represent the shortest distance between two points.
  • Another viewpoint suggests that in embedded spaces, using the metric from the ambient space can also be valid, highlighting the Whitney embedding theorem's implications.
  • Concerns are raised about the necessity of a chosen metric to define the infimum distance over curves, with examples illustrating discrepancies between intrinsic and extrinsic metrics.
Participants express multiple competing views regarding the definition of distance and the role of geodesics, indicating that the discussion remains unresolved with no consensus reached.
Limitations include the dependence on the choice of metric and the potential for discrepancies between intrinsic and extrinsic distance measures, as well as the conditions under which a geodesic may or may not minimize distance.
gikiian
Is it the shortest distance thru the non-flat space; or is it the simple displacement a middle-school student would imagine?
It's the length of the shortest path lying in the space (so option #1). In other words, the distance between two points in a 2-d space is defined as the distance "as measured by 2d beings whose universe is said space".
Oh, alright! I need one more clarification. Is this the same thing as geodesic?
We measure the distance between two points P and Q like so:
1) We consider consider all the smooth curves between P and Q.
2) We record their length and put them in a set S.
3) We say that the distance d(P,Q) between P and Q is the infimum of that set (i.e. the largest number that is smaller than all the numbers in S).
The infimum of a set is not necessarily an element of that set (for instance, the infimum of the set S={all real numbers >0} is 0 but 0 is not in S).
What this means for our definition is that the distance between P and Q might not be realized by any particular curve (there might not be a curve c between P and Q whose length is d(P,Q)). This is the case for instance in the space obtained from the plane by removing a point, say the origin, (0,0). Then, in cartesian coordinates, the distance between the points P=(0,-1) and Q=(1,0) is 2 but there are no curves of length 2 joining P and Q: there is only a sequence of curves whose length is arbitrarily close to 2.)
If is a fact however that if the distance is realized by some curve c, then c is a "geodesic". A geodesic is defined as a curve whose acceleration is 0. So it serves as generalization to the notion of a "straight line" in the plane.
that is the intrinsic approach, but for an embedded space, like a sphere in three space, it seems acceptable also to use the restriction of the 3 space metric. I think quasar is giving you the preferable way, but maybe not the only way. ?
sometimes the ambient space is easier to deal with than the intrinsic manifold.
e.g. the whitney embedding theorem tells you that you can embed manifolds in euclidean space. this has as a useful corollary that you can also define a metric on the manifold, and even a triangulation.
If there is a distance minimizing curve between two points then it will be a geodesic. But in some spaces there is no distance minimizing curve.
Also a geodesic may not minimize distance. It will do so locally, that is for small enough distances, but not necessarily for large distances. Although it is true that a distance minimizing curve is a geodesic, a geodesic may not be a distance minimizing curve.
Quasar:
Don't you need to start with a choice of metric so that you can select the infimum over the collection of all curves? i.e., in order to define d_L:=inf{d(x,y)} over all rectifiable curves joining x and y, we must start with a notion of d .
To add to your and Mathwonk's example, (example is also given in above Wikipedia link), the circle with the subspace metric does not generate an intrinsic metric, since the Euclidean distance between any x,y on the circle does not equal the arc-length distance, i.e., there are no arc-length paths of length equal to the Euclidean length between points, say, for (-1,0) and (1,0), there are no arc-length paths of length 2 in S^1 between those two points.
Indeed.
  • · Replies 30 ·
  • · Replies 16 ·
