My 3rd question - About Stellar Spectrum
  • Context: Undergrad
  • Thread starter Thread starter ThomasJoe40
    Spectrum Stellar
The discussion centers on the relationship between temperature, pressure, and the broadening of absorption lines in stellar spectra. It establishes that higher temperatures and pressures result in increased atomic collisions, leading to broader absorption lines due to Doppler and collisional broadening mechanisms. The conversation highlights three primary mechanisms of spectral line broadening: Natural Broadening, Doppler Broadening, and Pressure Broadening. Additionally, it addresses the constancy of the area of the absorption line, which remains the same despite variations in width and intensity.
  • Understanding of electromagnetic spectrum in astronomy
  • Familiarity with atomic collisions and energy levels
  • Knowledge of Doppler effect and Maxwell-Boltzmann distribution
  • Basic concepts of spectral line broadening mechanisms
  • Research "Doppler Broadening in stellar atmospheres"
  • Study "Pressure Broadening and its effects on spectral lines"
  • Explore "Natural Broadening and Heisenberg's uncertainty principle"
  • Investigate "Maxwell-Boltzmann distribution in astrophysics"
Astronomy students, astrophysicists, and researchers interested in stellar spectroscopy and the physical principles governing spectral line broadening.
ThomasJoe40
Hello, all
I have just read some foundamental concepts about EM spectrum in astronomy. One thing I don't quite understand is that "Stars with higher temperature or higher pressure shows a broadened line on its absorption spectrum". A brief explanation states that a higher temperature or pressure leads to a greater number of atomic collisions each time.
I am not absolutely convinced with the relation between atomic collision and broadening absorption line. An assuption I made is that the KE produced by collisions between atoms or ions does not absolutely fit the certain energy levels of an element (Hydrogen?). So, the broad of an absorption line is due to these random collisions. With higher the temperature or pressure, there should be a greater probabilities of collisions in each instance, which should leads to a broader line.
One last thing I can't figure out with is that the area of the absorption line (width times intensity) is always the same (same energy produced) Why? :confused:
Astronomy news on Phys.org
There are three main mechanisms causing the broadening of spectral lines:
  1. Natural Broadening (due to Heisenberg's uncertainty principle)
  2. Doppler (thermal) Broadening
  3. Pressure (collisional) Broadening
It seems that OP is mixing together mechanisms 2. and 3. in his post.
The source of Doppler Broadening is the fact that in thermal equilibrium the atoms in the stellar atmosphere are moving randomly with velocities described by Maxwell-Boltzmann distribution. The light emitted or absorbed by the atoms is affected by Doppler effect: blue-shifted or red-shifted depending on the atom's velocity relative to the observer. The higher is the temperature, the wider is the distribution of velocities of the atoms and thus the broader line observed.
On the other hand, in case of the Collisional Broadening, the width of the spectral line is proportional to the density of the gas. The denser is the stellar atmosphere, the more frequent are the collisions and the broader is the line. This mechanism also explains the MK luminosity classes: The more luminous giant stars have lower densities in their upper atmospheres and thus their spectral lines are narrower. On the other hand, main-sequence stars have denser atmospheres where collisions are more frequent and thus the spectral lines are broader.
This doesn't make sense to me. I don't think it is truth.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 109 ·
  • · Replies 35 ·
