| New Reply |
VRaptor SATA2.0 vs SATA3.0 |
Share Thread | Thread Tools |
| Aug18-11, 12:02 AM | #1 |
So I'm building a new workstation right now, and by no means is this the first time. The board is an ASUS P8P67, and the CPU is an Intel 2500k. I plan on running the OS off of a RAID0 array. I image my OS partition on a regular basis, so I'm not worried about being in RAID0. My question is this. I can either go with two WD 74 Gb VelociRaptors or two Segate 500 Gb drives. Normally this would be a no brainer, I'd go with the 10k drives. But the WD drives are ATA/300, while the Segate drives are ATA/600. How will these two drives compare in performance? Does SATA 3.0 have as much an impact as a SATA 2.0 drive running at 10k RPM's?
This is a desktop workstation, I'm not concerned about gaming. Much more concerned with CAD and applications. Any thoughts? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Aug18-11, 12:36 AM | #2 |
Check out the maximum burst read speeds for the hard drive. If it's lower than SATA2's 375MB/s capabilities, I wouldn't bother with SATA 3 worries. And I highly highly doubt it's even 150MB/s burst.
| Aug18-11, 05:51 AM | #3 |
Recognitions:
Sata 2 transfer rates exceed the streaming rates of any current hard drive.
The 10,000 rpm drives will have a faster average seek time. the streaming transfer rate might be better on the 7,200 rpm drives if those are based on newer tehcnology with sufficiently higher bit densities to compensate for the slower rotation rate. There are also SSD (solid state) drives from 40GB to 600GB, but I'm not sure of the streaming rate versus the latest drives, probably the Seagate XT 2GB hard drives, with max rates over 100 mega-bytes per second. You may be able to use a utlity to "destroke" (usually a mode select command) a hard drive, reducing it's capacity by only using the outer diameter (faster streaming rate). |
| Aug18-11, 12:54 PM | #4 |
| Aug18-11, 01:39 PM | #5 |
Recognitions:
| Aug18-11, 01:45 PM | #6 |
Wouldn't limiting the partition size be essentially the same thing? I mean, if is a 500GB drive, and you set up a partition that's only 100GB, wouldn't this be similar? The only difference being that maybe you wouldn't have control over where the data is being stored on the platters themselves?
| Aug18-11, 03:30 PM | #7 |
| Aug18-11, 03:53 PM | #8 |
Recognitions:
This document from Seagate mentions using mode select to destroke drives, but doesn't mention where to get the utlity that does this. I'm guessing that raid controllers (ones you plug into a PCI or PCI Express slot) come with software utilities to do this. http://www.seagate.com/docs/pdf/en-G..._readiness.pdf For a home user, since the first partition will end up on the outer diameter of the first surface, you can keep the first partition on each drive relatively small (100GB would use a bit less than 1/2 of the 250GB per surface). |
| New Reply |
| Thread Tools | |
