Troubleshooting ERR:SYNTAX on TI-83+ with asm programming
  • Context: Calculators
  • Thread starter Thread starter Schwazz
    Programming Ti-83
The discussion revolves around troubleshooting an ERR:SYNTAX message encountered while attempting to run an assembly program on the TI-83+ calculator. Participants explore potential causes and solutions related to assembly programming, syntax differences between TI calculator models, and software installation for downloading programs.
  • Homework-related
  • One participant describes their experience with assembly programming on the TI-83+, noting an ERR:SYNTAX message when trying to run their program and seeking assistance.
  • Another participant suggests using built-in assembly commands like "asm(" or "asmprg(" to run the program, cautioning about potential issues with the calculator.
  • A different participant mentions a FAQ by Patrick Davidson that might address the syntax issue, directing others to the FAQ on his website.
  • One participant points out that the syntax for running programs differs between the TI-83 and TI-83+, indicating that the original tutorial may have been for the TI-83 and suggesting the need for a TI-83+ compiler.
  • Another participant shifts the topic to downloading software for the TI-86, expressing confusion about the process.
  • A response provides a step-by-step guide for installing TI connect software and downloading programs, but it is not directly related to the original assembly programming issue.
Participants express differing views on the correct syntax and methods for running assembly programs on the TI-83+. There is no consensus on a single solution, and multiple approaches are suggested.
Some participants indicate that the syntax and file types for the TI-83 and TI-83+ differ, which may affect program compatibility. There is also mention of potential risks associated with assembly programming, such as freezing the calculator.
Individuals interested in assembly programming for TI calculators, particularly those working with the TI-83 and TI-83+ models, as well as users seeking guidance on downloading software for TI calculators.
Schwazz
I've been trying to learn asm for the TI-83+ for the last month or so. I've read a bunch of tutorials, and at some point they all say to send the program to the calculator and then type "Send(9prgmNAME" (in my case, TEST) in either the home screen or a new BASIC program to run it. I had no problem getting the program onto the calculator, but whenever I try to run it an ERR:SYNTAX message pops up and points to the "9". I have no clue what I did wrong. Could someone help me?
If it makes finding an answer easier, here's the code:
.NOLIST
#define equ .equ
#define EQU .equ
#define end .end
#include "ti83asm.inc"
#include "tokens.inc"
.LIST
.org 9327h
ld a, 3
ld b, 6
add a,b
call _setxxop1
call _stox
ret
.end
END
Computer science news on Phys.org
I've haven't programmed with ASM in a long time, but here goes. I think with the TI-83 it has a built in asm interpreter. Press 2nd + Catalog and it will bring up a list of commands. scroll down to something like "asm(" or "asmprg(". Try those commands.
Code:
asm(<program name>)
Oh, and be careful with ASM. although you can rarely break your calculator with it you can put it out of service for about a day. You can get some very bad freezes.
-HBar
Figure it out?
If you didn't figure it out yet, I think Patrick Davidson has something about this problem in his FAQ. You can find this on his website at http://pad.calc.org/.
asm blues
All the syntax for sen(9"program name") is only for the ti-83. It does not work the same on the ti-83+. Chances are if that is what you learned in a tutorial you have compiled the program for the ti-83. You need to find a ti-83+ compiler. I just started to get my asm programs to work and if u need to know where i got my compilier e-mail me at moo_cow0486@yahoo.com and I can try and find it again. The files for a 83 plus are different from an 83. 83+ files are called prgmname.8xp 83 files are prgmname.83p the 83 files won't work on the 83+.So if you have any probs e-mail me or I am me at MooCow04862004 on AOL IM.
While we are on the topic of TI calc programming.. I am new to the downloading of software from the Internet from my TI-86.. I am totally lost on how to even start d/ling! I received a CD with the connector..Anyone help me please! Thanks :P
First install the TI connect software. Next go to any site with calculator programs such as http://www.ticalc.org and download the programs you want. Connect your calculator to your computer using the graph link you hopefully have if you are asking this question. If you are using TI connect open up the calculator explorer and drop the programs you downloaded from my computer to the calc explorer.
9K
9K
10K
9K
17K
