Difference in Distributed Loads: Up vs Down, -30kN/m
  • Thread starter Thread starter TyErd
    Distributed
The discussion revolves around understanding the implications of a distributed load represented with arrows pointing upwards versus those pointing downwards, specifically focusing on a value of -30 kN/m. Participants are exploring the meaning of the negative sign and its effect on the direction of the load acting on a beam.
  • Participants are questioning whether the direction of the arrows indicates the actual direction of the force acting on the beam. There is a discussion about the clarity of the diagram and the interpretation of the load as either pressure or a uniformly distributed force.
The discussion is ongoing, with participants providing insights and seeking clarification on the nature of the load and its representation. Some guidance has been offered regarding the interpretation of the load, but there is no explicit consensus on the implications of the negative value or the diagram's accuracy.
There is mention of a larger question related to the diagram, and participants are encouraged to provide additional context to clarify the situation. The discussion also touches on the potential confusion arising from the representation of the load and its measurement units.
TyErd
what is the difference between a distributed load with arrows pointing up like the once i have attached and just the standard distributed load where the arrow is pointing down. Does it mean the force is acting up the beam instead of down?the value given is -30kN/m. does that mean its actually a load acting downwards
None
That sort of just means that the load is on the underside of the beam.
but then would the negative 30kN/m change the direction? meaning its acting downwards on the beam?
I think in copying the diagram you have lost some of its clarity. Are you sure it's a beam? Maybe it's two beams or bodies, with the lower one supporting the upper one? (Like a man lying on a bed of nails.)
As you can't have a force without an opposing one, then if the lone arrow represents pressure (and it would be better to have multiple arrows for this), then the multitude of up arrows should indicate the beam's reaction. (A more vivid interpretation would be that this represents the cross-section of a wall of a pressure or vacuum vessel.)
The fact that you have pressure written as kN/m doesn't give confidence that the diagram is exactly correct. Maybe it isn't pressure; maybe it's a single force. And why a curved arrow?
You need to supply the context in which the diagram arises.
sorry about that, its just part of a larger question which i have in another thread. I have attached the complete diagram.
What quantity is measured in kN/m ?
Do you mean this to be pressure, or moment, or ... ?
its a uniformly distributed force/load which can then be simplified to a point load (single force as you mentioned earlier)
Ah, now I understand. Two separate sketches would have been better.
So has your question been answered? In fact, what was your question?
Probably this would arise as: what single force applied to the end of the beam would exert the same torque about the beam's point of attachment as does a uniformly distributed load along the length of the bean of x N/m.
  • · Replies 38 ·
